Pages: [1] 2 3
Author Topic: Wood usage.  (Read 22711 times)
Jared43758
  • OWF Model: C250
Wood usage.
« on: December 28, 2014, 01:48:36 PM »
Using a 5000e or c250, how much wood would a person figure to use with a moderate insulated 2500sqft home and dhw.
Stihl MS290
Stihl MS660 Magnum
Husky 21 ton splitter
Southeast Ohio
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: Wood usage.
« Reply #1 on: December 28, 2014, 03:00:54 PM »
What climate region do you live in? Are your underground lines well insulated?
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
Jared43758
  • OWF Model: C250
Re: Wood usage.
« Reply #2 on: December 28, 2014, 03:10:58 PM »
Southern Ohio. Rehau insulated foam filled line. 50 ft underground.  Red oak wood.
Stihl MS290
Stihl MS660 Magnum
Southeast Ohio
CountryBoyJohn
Re: Wood usage.
« Reply #3 on: December 28, 2014, 03:17:54 PM »
I'm going to take a non-binding no implied liability can't blame me if I'm wrong guess and say 5-8 chords of good hardwood.
Stihl MS290
Woodchuck Log Jack
Knox County, IN
Jared43758
  • OWF Model: C250
Re: Wood usage.
« Reply #4 on: December 28, 2014, 03:34:00 PM »
Now figure in the use of bit coal to supplement
Stihl MS290
Stihl MS660 Magnum
Southeast Ohio
Re: Wood usage.
« Reply #5 on: December 28, 2014, 03:47:17 PM »
I don't own a Heatmaster 5000 or a Heatmaster for that matter but I am going to guess higher at 8-10 cord minimum.
Jared43758
  • OWF Model: C250
Re: Wood usage.
« Reply #6 on: December 28, 2014, 03:49:53 PM »
From what I understand a Hardy uses double the wood
Stihl MS290
Stihl MS660 Magnum
Southeast Ohio
Jared43758
  • OWF Model: C250
Re: Wood usage.
« Reply #7 on: December 28, 2014, 03:53:25 PM »
Countryboy, didn't I read somewhere u used 8-9 cords to heat 4600sq ft and dhw from September to march in a mf10000?
Stihl MS290
Stihl MS660 Magnum
Southeast Ohio
CountryBoyJohn
Re: Wood usage.
« Reply #8 on: December 28, 2014, 04:51:21 PM »
No. I burned 13 last year, but only 6 cords were hardwood. And I burned from mid October to the end of March or April. And I was heating 3500 sft of poor insulation up to 74°, domestic water and a hot tub. And last winter was nuts!
Stihl MS290
Woodchuck Log Jack
Knox County, IN
Re: Wood usage.
« Reply #9 on: December 28, 2014, 05:51:07 PM »
Time will be the only sure answer as to how much wood you will burn. Yes Hardys are less efficient then the e series from heatmaster.  I go through 12 cords in the 6 months of heating. I am heating 2400 sqft in New England. He should have a little bit better efficiency with the e series and he is probably a little bit better insulated then I am. That is why I say 8-10 cords. I don't think anyone is using under 8 cords with a conventional owb on this forum unless they have 1600 sqft or less. Pipe in if you are someone who used less then 8. If you want to get below the 8 number you will need to be looking at a gasser.
Jared43758
  • OWF Model: C250
Re: Wood usage.
« Reply #10 on: December 28, 2014, 06:03:35 PM »
As I break that down it is unbelievable to me. That's two cords a month. That is a entire 8 ft bed truck clear full of wood every single week, repeat every single week for the entire 6 months spand. Burning that much wood is what gives owb the name forest eaters. That blows my mind
Stihl MS290
Stihl MS660 Magnum
Southeast Ohio
CountryBoyJohn
Re: Wood usage.
« Reply #11 on: December 28, 2014, 06:14:50 PM »
It's all in perspective. I have no problem cutting, splitting, stacking, hauling, and burning that much wood because it makes my home comfortable and affordable. My hearing bill was over $700 a month in the winter and now it's $150. That makes it with it for me.
Stihl MS290
Woodchuck Log Jack
Knox County, IN
Jared A
  • OWF Model: MF 5000e
Re: Wood usage.
« Reply #12 on: December 28, 2014, 06:18:41 PM »
First year with a 5000e and live in southeastern Ohio. I also have rehau insulated pipe. My house is aprox 1500sq ft with a 1500sq ft unfinished basement. Started the boiler on Halloween and probably have burned 2 cords of wood.  Just want to say thanks to all the guys on this site, all the info helps newbies like me.
Jared43758
  • OWF Model: C250
Re: Wood usage.
« Reply #13 on: December 28, 2014, 06:24:10 PM »
Jared hear also. Also from southeast Ohio.  Morgan county  you?
Stihl MS290
Stihl MS660 Magnum
Southeast Ohio
Jared A
Re: Wood usage.
« Reply #14 on: December 28, 2014, 06:28:51 PM »
Live in Vinton County now, but grow up in Blue Rock in south Muskingum County.
Pages: [1] 2 3
