Author Topic: 250 stack temp  (Read 6601 times)
american-pacemaker
  • OWF Brand: P & M
  • OWF Model: OPTIMIZER 250
250 stack temp
« on: December 29, 2014, 05:54:42 AM »
Hey SlimJim I am still struggling to get my stack temp over 215 deg  >:(  My temp is set to 190 with a 5 deg diff and high limit of 210 deg. My air box is 4 turns on the bottom and 5 turns on the top. My wood is dry and I have tried hardwood and mixing in pine. I also have a lot of creosote or at least I think so. The heat exchanger has a real fine brownish and grey powder on the shelf if that helps. Any suggestions ? Thanks for all the help on the phone last week.
Re: 250 stack temp
« Reply #1 on: December 29, 2014, 06:58:00 AM »
As long as there is no moisture in the heat exchanger, you are fine! The temp probe may not be accurate.
american-pacemaker
  • OWF Brand: P & M
Re: 250 stack temp
« Reply #2 on: December 29, 2014, 07:03:00 AM »
Thanks SlimJim, it was nice to have to open windows xmas day instead of listen to people bitch the house is cold !!!!!!!!!!
Winalov
Re: 250 stack temp
« Reply #3 on: January 07, 2015, 08:01:56 PM »
I had the same problem with stack temp. My OPT 250 heat exchangers were equipped with those stainless steel  blades.
I stopped using them in lower HE. That helped the situation. Also keep that thing clean.
Not to much ashes on the bottom of the fire box.
Ho , ho, ho with wind below ZERO rigth here in NJ Dallas Cowboys and Man United Country :thumbup: :o >:D
HAPPY NEW YEAR !!!!!!Keep the fire burning!!!!! ;D
JTS717
  • East-Central Wisconsin
Re: 250 stack temp
« Reply #4 on: January 09, 2015, 11:42:44 AM »
I guess i'm not sure why you want your stack temperature higher.  Mine is around 230 after I clean the tubes and usually around 250 before cleaning.
american-pacemaker
  • OWF Brand: P & M
Re: 250 stack temp
« Reply #5 on: January 09, 2015, 12:16:05 PM »
Slimjim said to try to keep it around 260 and clean the boiler around 300 when I bought it.
Re: 250 stack temp
« Reply #6 on: January 09, 2015, 01:35:28 PM »
I can't get mine above 230 when it's clean. As long as no creosote forms in the pipe you should be good.
