Author Topic: New install  (Read 17370 times)
Jonathan8186
  • OWF Brand: None
  • OWF Model: None
New install
« on: December 29, 2014, 07:17:04 PM »
Looking for some help. I purchased a CrownRoyal 7300 and I'm in the process of having the house built and would like to know what items should I address? Is there anything I should have installed to make it easier to install the boiler after construction?
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
Re: New install
« Reply #1 on: December 29, 2014, 07:19:37 PM »
Might as well put your underground line in while the excavators are still there.
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
Re: New install
« Reply #2 on: December 29, 2014, 07:36:28 PM »
If you haven't had the foundation poured yet then pour the pad for the boiler when they come to do the foundation. Also if they haven't done the foundation yet then put something in the forms to give you a 6 inch hole through foundation wall for your piping.
Jonathan8186
  • OWF Brand: None
  • OWF Model: None
Re: New install
« Reply #3 on: December 29, 2014, 07:37:09 PM »
Ok thanks. Do I have to have 120 volts to the boiler?
Jwood
Re: New install
« Reply #4 on: December 29, 2014, 07:38:37 PM »
Yes you do
Stihl MS 270c
Stihl MS 461
Jonathan8186
  • OWF Brand: None
  • OWF Model: None
Re: New install
« Reply #5 on: December 29, 2014, 07:41:03 PM »
I have poured the concrete pad and installed a rail system for the wood. I also put a roof over all of it.
Anything on the inside of the house I need to do?
Re: New install
« Reply #6 on: December 29, 2014, 08:02:10 PM »
Attach a 4x6 of 4x8 sheet of ply to the basement wall near your boiler or furnace so that you can mount your HX and plumbing from the owb right to it.
Re: New install
« Reply #7 on: December 30, 2014, 02:52:24 AM »
Look at Ultra Fin radiant floor heat before the ceilings go up!
Jonathan8186
  • OWF Brand: None
  • OWF Model: None
Re: New install
« Reply #8 on: January 13, 2015, 04:46:45 PM »
Thanks for everyone's input. Does anyone have a diagram for the plumbing? I have a electric hot water tank and eletric heat pump / air handler.
Re: New install
« Reply #9 on: January 14, 2015, 03:27:17 AM »
Each installation will be different, can you give us a better idea of what you are heating and what you want to heat with, a drawing would help!
caper
  • OWF Brand: heatmaster 5000
Re: New install
« Reply #10 on: February 02, 2015, 07:16:11 PM »
just another thought, u should run a water line and additional wiring for outside barns,sheds etc,,,,,while drench is dug and holes are walls, in my mind this is a huge advantage....
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Cape Breton, Nova Scotia
Canada
Re: New install
« Reply #11 on: October 18, 2015, 09:24:22 AM »
Absolutely.
When I installed the Logstor last fall to replace my original line I went ahead and buried a water line and installed a hydrant. Right next to the OWB and the driveway, a 30 foot piece of hose is enough to be able to give something a quick spray down instead of messing with all that garden hose like before.
