Author Topic: SETTING TEMP ON A C.B.  (Read 7408 times)
homelite
  • OWF Brand: central boiler
  • OWF Model: 4030
« on: November 04, 2010, 11:00:11 AM »
 I read the manual last night to set my boiler down to 165 / 175. It came from the factory @ 175 / 185. Has anyone done this or could give me a pointer. The manual says how to set the Hi side but doesn't tell how to set the low side. Thank you for any pointers.
ryan4030
  • Husqvarna 353 16"
Re: SETTING TEMP ON A C.B.
« Reply #1 on: November 04, 2010, 07:43:08 PM »
On my CB 4030 the low side is automatically set 11 degrees below the high setting. When my high temp was set at 185 the draft door opened at  174  Hope I helped you out.
jackel440
« Reply #2 on: November 04, 2010, 07:52:23 PM »
way to jump in there on your first post! :thumbup:
Welcome to the forum both of ya. :D
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
homelite
  • OWF Model: 4030
« Reply #3 on: November 05, 2010, 05:48:14 AM »
Thanks for the info, I have a 4030 central boiler also . Heating 1250 sq.ft. with side arm heat to my water heater. I guess I have never turned the gas off to my water heater to know if I would run out of hot water. This is my first winter with it . I live in mi. I hope the unit is big enough. The dealer asured me it was. Last night it got down to 29. I put 4 peices  of oak in it when I left for work this morning it still had 3 peices in it @ 7:00 a.m. approx. 10 hr.
gyro684
« Reply #4 on: November 19, 2010, 07:16:49 PM »
I have  a CB 5036 and works the same way set the high tepm that you want and the low temp is automatic at 10 degrees be low the high temp I am heating a 2000 sq ft 100 yr old farm house with mine with a flat plate exchanger on the water heater and have not had the gas on for 3 yr. love that wood heat  "FREE"
Ken G
sidney Oh
central boiler 5036
stihl farm boss
