Author Topic: Boiler  (Read 12228 times)
ijon
  • OWF Brand: Portage and main
  • OWF Model: 28-40
Boiler
« on: January 02, 2015, 07:17:13 PM »
How many of you have went away for extended periods of time and just left your boilers unattended with just the pump running. This might seem stupid, but I am just checking my options for going away.
installed in 2014
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: Boiler
« Reply #1 on: January 02, 2015, 07:25:06 PM »
I've gone away for up to nearly 3 days. But, I have a large stove that can hold the amount of wood I need to make it that long. Generally, I like to have someone check in on it once a day if not to load at least to check on things.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
BoilerHouse
  • OWF Brand: Home Built
Re: Boiler
« Reply #2 on: January 02, 2015, 07:36:46 PM »
Depends on how your system is configured.  I have been away for a week in the dead of winter with no ill effects.  Heat from the oil forced air system back feeds into the boiler's plenum heat exchanger and keeps boiler water at 80 deg F.
Muskoka, Ont
juddspaintballs
Re: Boiler
« Reply #3 on: January 02, 2015, 08:15:43 PM »
Yep, I let my heat pump and water heater keep my boiler from freezing.  Heat exchangers work both ways...
AirForcePOL
  • OWF Model: G400
Re: Boiler
« Reply #4 on: January 02, 2015, 08:33:25 PM »
I don't have another source of heat so I've put a little electric heater in the firebox when I've left before.  Temp was around 75 when I got back after a few days.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
ijon
  • OWF Model: 28-40
Re: Boiler
« Reply #5 on: January 03, 2015, 06:23:22 AM »
Thanks.
installed in 2014
Big Wood
Re: Boiler
« Reply #6 on: January 03, 2015, 06:35:16 AM »
I just fired up our CB 2300 at the store last week so the pump was on from November and December picked up the heat from the store and stayed 50 degrees
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
Re: Boiler
« Reply #7 on: January 03, 2015, 11:24:29 AM »
Great read!
I guess the weak link in the whole set-up, is boiler pump failure.
I guess for a long holiday one would drain the system .
Then I guess Rust in the boiler would be the issue.
kk
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
userdk
  • OWF Brand: Heatmaster SS
  • OWF Model: G 400
Re: Boiler
« Reply #8 on: January 06, 2015, 01:41:04 PM »
Have someone stoke it for you.
browncty
  • OWF Brand: American Royal
  • OWF Model: 7400B
Re: Boiler
« Reply #9 on: January 29, 2015, 06:28:54 AM »
I have someone who can fill mine I'm out of town with the family. He burns wood so he doesn't mind.
