Author Topic: I'm on my 3rd solenoid  (Read 21070 times)
ffbare
  • OWF Brand: ridgewood
  • OWF Model: 6000
« on: January 03, 2015, 07:42:20 AM »
Hey guys just wondering why I keep going through solenoids? After 2 months or so of my new stove I'm on my 3rd solenoid,  the only thing I can think of is maybe creosote is making the damper door stuck closed maybe? It seemed a little stuck but it could have done this because the Temps got so low it sealed it self shut. When I did pull it up manually it didn't seem to take much effort so I doubt that was the issue.   Anyone else have bad luck with the solenoids?  Boy am I glad I bought 2 extras now I'm down to 1 spare one the shelf.
Polk wisconsin.   Husky saws, 27ton husky splitter,  gehl skid, tb016 excavator
automan77
  • OWF Model: 6000
  • Just say no to propane
Re: I'm on my 3rd solenoid
« Reply #1 on: January 03, 2015, 07:47:24 AM »
I keep it clean and spray lube on it once every couple weeks. On my second season with no issue.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
fsuftball
  • OWF Model: 6000
« Reply #2 on: January 03, 2015, 01:39:53 PM »
i havent touched mine, no problems thus far.
Dawnpatrol
« Reply #3 on: January 03, 2015, 06:58:20 PM »
Where did u buy the spares from and how much are they?
automan77
  • OWF Model: 6000
« Reply #4 on: January 03, 2015, 07:11:32 PM »
Ridgewoodstove has them for  28
Scott K
Stihl ms 311
Husky 455
ffbare
  • OWF Model: 6000
« Reply #5 on: January 03, 2015, 09:38:53 PM »
I picked mine up from grainger they had them in stock so I picked some up after my first one went out a month into my first burning season.  I'm very glad I did if I hadn't planned that one ahead I would be screwed. The price sounds close to what I paid.
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
  • Southeast Michigan
« Reply #6 on: January 04, 2015, 07:26:21 PM »
I'm guessing your draft door is being glued shut by creosote. Clean up the area and put a paper clip on the bottom of each side of the draft door leaving a gap no larger than 1/16". That should fix your problem.
What temps are you running? Bump em up to keep a good coal base. I recommend 175 low - 185 high.
Message me if you have questions
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Stihl 036pro, 362c, 064
Husk 385,570
Shindiawa 416
Griffin 14' Dump
ffbare
  • OWF Model: 6000
« Reply #7 on: January 05, 2015, 04:21:14 PM »
RosCoe that is exactly what I am thinking I will try the paper clip idea for sure. I'm guessing that should do the trick. I'm running 180 high 170 low that was preset. I could bump it up.
automan77
  • OWF Model: 6000
« Reply #8 on: January 05, 2015, 06:43:28 PM »
Bump it up to 185/175. That will cure it.
Scott K
Stihl ms 311
Husky 455
Chicken farmer
  • OWF Brand: Ridgewood
  • OWF Model: 2000
« Reply #9 on: January 06, 2015, 04:04:13 PM »
Something else to check. Depending on how far your stove is from the electrical connection (and the size of the conductor), you could be seeing a voltage drop. If the voltage is too low, it will cause the coil of the solenoid to heat up (excessively), which, in turn, could cause premature failure. I believe electrical devices are designed to handle a 10% fluctuation from the rated input voltage. Ex. 120 volt rating 10% of 120 is 12, acceptable voltage range - 108 to 132. I would say that anything above 105 volts ought to be fine, but if you get into the 90's, you could get excess heat.
30 yrs burning wood - new to the boiler scene
Midwestern Ohio
« Reply #10 on: January 06, 2015, 05:59:48 PM »
 :post:
automan77
  • OWF Model: 6000
« Reply #11 on: January 16, 2015, 03:06:06 PM »
 I Clean the creosote off before I  load everyday  and have never had a issue. Don't let it get gummed up
Scott K
Stihl ms 311
Husky 455
jamesbodeis
  • OWF Model: 7500
« Reply #12 on: January 16, 2015, 04:08:54 PM »
I have been burning since september and have not had an issue with the solenoid yet. 190 on 195 off. Burning wet wood and i dont have hardly a drop of creosote on the door.
Ridgewood 7500
The thumb of michigan.
Jonsered 2260
fireboss
  • OWF Brand: central boiler
  • OWF Model: 6048
« Reply #13 on: January 16, 2015, 05:33:31 PM »
I no I have a different stove but  I to burn wet green pine wood and my settings r 185/195  and have no problems !
Chas
  • OWF Model: 6000
« Reply #14 on: January 16, 2015, 05:38:02 PM »
My Ridgewood was built the same week as Automan77's and I haven't had any issues with mine either, 2nd season... still the original solenoid. I don't know if they switched brands or what but it seems odd that they're having issues with the ones on the newer stoves.
Dolmar 035
Stihl 026
Stihl 260
Speeco 25 ton splitter
John Deere 4720
Polaris Ranger 800
Middle of the mitten, Michigan
