Author Topic: What do OWB have to offer, that indoor don't. Excluding mess and fire outside?  (Read 18699 times)
WoodHeatIrritatesMyWife
  • OWF Brand: None
I'm weighing the options.
1800 sq ft 1.5 story home.
Masonry walls (blocks of stone, not brick), roughly 2.5 feet thick (from outside to inside lathe and plaster).
Insulation in the ceiling.
Windows are 12 years, double pane.
Fieldstone foundation, drafty.
Currently heating with oil (forced air).
I am looking for an in-expensive (not cheap) way of heating with wood, where I don't need to enter the crawlspace to feed the beast
I am looking for something that has decent length burns (I hope 12 hrs), non-stainless steel(I like the idea of simple welds if crap breaks down), that doesn't require me to push half a forest a year into it and finally,
Videos which just blow my mind as "Holy crap, that's horrible":
https://www.youtube.com/watch?v=Y5Mgn2po54c (6:25->6:28 also proves why she should be wearing steel toes if she isn't).
Right now, I'm considering an indoor wood boiler system (with thermal storage).
I'm still considering a PSG Caddy type system, even though it breaks my "not wanting to enter the crawlspace".  Although, this is unlikely.
What are you thoughts on what I am missing on looking for a system that could be mainly a heat exchanger in the forced air and probably a rad or two in the future?
Thanks!
I'll let some of the experts answer the more technical aspects of this and cost but some clear advantages of a OWB over a indoor unit:
1: Dirt, bugs, and ash all stay outside where they belong.
2: With a OWB you don't need near as well seasoned wood as you do with an indoor unit, chimney fires are completely eliminated with a OWB.
3: Size it accordingly and with a OWB you could heat additional out buildings at a later date while a indoor unit may not have the capacity.
4: Not sure about Canada but your home insurance should be lower with a OWB compared to an indoor unit.
  • OWF Brand: None
Chimney fires are a concern for sure, but I'm a paranoid person.  If I can get the chimney outside and up the wall, I would likely
watch the creosote like a hawk and clean it frequently.  This isn't trying to say one is better than the other, just that because I am aware of a possibility of a fire, I would certainly try to reduce the chances of it for sure.
Quote
Yeah, I'm having a hard time sizing it.   The house for sure, I see a heat exchanger in the Forced Air, maybe a rad or two throughout the house (kitchen, bathroom).  The main floor in exposed in the ceiling of the crawlspace, so radiant heat is an option for sure, other possibilities I may size for is a modine in the crawlspace to keep it warm and one in a mini-uninsulated space outside (maybe).
Quote
50' away, thee wouldn't be a problem with insurance.
Thanks.
aries9245
  • OWF Model: Cl6048
That's one crazy chick!
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
Kubota l4610 tractor
2 sthil farm boss saws
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
What other reasons do you need besides mess and fire outside? Longer burn times than a wood stove, better indoor air quality.
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
  • OWF Brand: None
For clarity, I'm not looking at a wood stove, I'm looking at a Wood Boiler (or if it makes more sense, a wood furnace, which just doesn't really excite me).
Right now, my biggest problem with OWB's would be the potential smoke.
Also, I'm not only looking at an indoor wood boiler in the house, I have 2 sheds less than 80' away that I could stuff one into.
I don't want to turn into an angry Albertan, storming out in the middle of the night, filming a video about how much wood I go through, with a lack of sleep and such.
One thing I don't understand is, if I were only to put in a boiler system (indoor/outdoor) and a heat exchange in the forced air furnace, how effective would that be?
There is a local heating company who consistently tells me I'm not going to be happy with the heat output of a forced air with a heat exchanger at the registers.  So, this has me somewhat confused.  Can someone heat their house with a boiler with just a heat exchange in the FAF?
sceptre74
  • OWF Model: BL 28-40
I had been heating my house for 15 years with an forced air wood furnace. This is my first winter with my owb and a water to air hx installed in my existing duct work. It heats my house just as easily and nicely as the old system did. I would not go back to lugging wood into my basement and I definitely don't miss the mess that went along with it. See if you can find someone local with the setup you are looking at to see if it's the right thing for you
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
Put the stove downwind 50 ft from the house and no problem .
Ares is 30 feet away and the west wind here in central N. Ontario takes the smoke away.
Best thing we ever did was install this system OWB to a fanforced furnace.
We save $2-3k a winter on propane for a 1600 ft bungalo.
And we can put wood in it [W.4400] once or twice a day at -10/20 C
Go for it!! :thumbup:
KK
« Last Edit: January 03, 2015, 10:56:34 AM by kommandokenny »
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
kommandokenny
  • OWF Model: 4400
Bet this company doesn't sell OWB,S
KK
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
Yes, you can heat your house with a water/air heat exchanger in your ductwork and be VERY happy.  The air temp coming out of the vents is probably going to be warmer than the oil furnace's hot air would be too.
If I had a nice outbuilding for it, I'd have an indoor unit in an outbuilding with all of my wood in it.  I have no desire to drag the wood mess into my house, though.  Trudging out in the snow to fill it kind of sucks sometimes, but you can do things to make it not so bad.  My last house, I built a shelter over the front of the boiler so it wasn't snowy where I was loading wood and with the concrete pad I had there, it was also a solid clean place to stand.  Sure, it gets cold out there, but I was getting 12+ hour burns so I only loaded 2x a day.  No big deal for consistent 74* heat in a very drafty old home.  Since I work 24-48 hours at a time, my wife had to load it often and she called the thing her best friend.
BoilerHouse
  • OWF Brand: Home Built
I live in central Ontario in an older 1400 sq ft farm house.  The current back up system is oil forced air.  My outdoor wood boiler is home built.  It is 165 feet from the house and 90 feet from the shop.   There is an 18 x 18 inch heat exchanger in the plenum which transfers boiler heat through the house and another similar sized HX for the shop.  Absolutely no problem keeping the house warm and comfortable, even at minus 30 or colder, and your local heating company which states otherwise is misinformed and incompetent.  Can't comment on how much wood you will burn. I go through 6 to 7 bush cords per year.  I believe people with gasifier models go through 6 cords or less, and those with the more conventional tank in a tank go through 9 cords but there is a lot of variability depending on outbuildings and heating domestic hot water.
Muskoka, Ont
Shrek1112
  • OWF Brand: Hawken Energy
  • OWF Model: HE-2100
I replaced an indoor wood forced air unit that was plenty warm but made the inside covered with fine ash and smelled like smoke, not a nice fireplace smell.  The Mrs hated then mess and smell so just installed a OWB about a month ago. I currently only have to feed it once a day with temps ranging from occasional mid 30's during the day 10F at night.  I have a water to air he in my plenum and the wife is complaint its to warm if we go above 70-71 and with two teenage kids we did a 30 plate water to water he and I have yet to run out of hot water after back to back to back showers and laundry and dishes.  We have minimal smoke during idle or full burn cycles just when the blower first kicks on.
Stihl MS-250
Stihl MS-391
Huskee 35 Ton
Chevy 1500 Crew
13 & 15 year old work force
  • OWF Brand: None
It's good to hear about someone who lives in central Ontario being able to heat with a HX only.  I'm considering a gasification model which ever way I go, simply because of my proximity to the highway (about 500ft <-- that way) and a neighbour (about 350' ---> that way).
  • OWF Brand: None
Yeah, I'm considering whatever way I go, to have a plate just for these very reasons :)  THanks.
Jeff5036
  • OWF Brand: Central boiler
  • OWF Model: 5036
    I live in eastern Ontario.  Running on my 8th winter with an outdoor boiler.  Simply put if you want to live in canada and heat with wood there is no easier better way to do it.  Our home is cleaner.  Our family is healthier because we don't have wood stored indoors.  We are not breathing in fine whits dust ash particles every time you have to take ashes out.  We heat 2 homes and all our hot water.  Our entire home is warm.  Always!!   Doesn't matter if get home at 6 in the evening or 3 in the morning stumbling drunk...house is warm!!  Easy to put wood in anyone can fill the furnace for u n close the door.  No need to have someone going in ur home and putting wood in playing with drafts etc.
