Author Topic: Saw not oiling?  (Read 9898 times)
Scratch
  • OWF Model: CB6048
    • Edge Metalworks
Saw not oiling?
« on: November 07, 2010, 08:43:19 PM »
I have a Husky 281XP that's not oiling the bar.
I've pulled the bar off and no oil comes out the port while running.
I've run thinner through it after letting it soak for a while... nothing.
I've tried compressed air....nada.
I used a hook to pull the suction tube up and pulled off the little filter... clean as a whistle.
Any other ideas...?
Hudson, WI
Re: Saw not oiling?
« Reply #1 on: November 08, 2010, 08:02:04 AM »
Is there any debris in the oil line?  Is the oiler adjustment set properly?
jackel440
Re: Saw not oiling?
« Reply #2 on: November 08, 2010, 10:00:18 AM »
Pump dead?
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
gandgracing
Re: Saw not oiling?
« Reply #3 on: November 08, 2010, 11:59:40 AM »
I know on my stihl ms290 there is an adjustment on the bottom side to adjust the bar oil.
Scratch
  • OWF Model: CB6048
    • Edge Metalworks
Re: Saw not oiling?
« Reply #4 on: November 08, 2010, 06:05:03 PM »
I didn't know there was an oil adjustment...  I don't see anything that looks like it might be an oil adjustment?  I don't think I changed it at all...
I didn't see any blockage in the line either.
Hudson, WI
Dirtslinger
  • OWF Brand: Woodmaster
  • OWF Model: 4400
Re: Saw not oiling?
« Reply #5 on: November 08, 2010, 06:11:31 PM »
There should be a screw on the bottom (may need to turn upside down to see it).side just below the drive sprocket you will need a long skinny flat head to adjust.
Dirtslinger
Brockway, PA
Re: Saw not oiling?
« Reply #6 on: November 09, 2010, 05:15:49 PM »
just because you didn't change the oiler adjustment doesn't mean vibration didn't do it for you
Scratch
  • OWF Model: CB6048
    • Edge Metalworks
Re: Saw not oiling?
« Reply #7 on: November 10, 2010, 12:00:44 PM »
Still can't find the oiler adjustment thingy.... going to have to bring it in I think.
Hudson, WI
