Author Topic: Need advice on water temperature settings  (Read 9634 times)
redleg105
  • OWF Brand: wood doctor
« on: January 08, 2015, 04:28:28 PM »
I have a Wood Doctor Outdoor Boiler that is being used to heat my home which has in floor ( radiant ) heating. The water temperature going through the house is 90 degrees F. I have the controls on the boiler set at 165 degree low limit with 5 degree offset and the high limit is 190 degrees. Are these settings correct for the type of heating I have? This is my first Winter in this home and my first experience with an outdoor wood boiler. Hope someone can help me out on this.
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
Re: Need advice on water temperature settings
« Reply #1 on: January 08, 2015, 04:38:46 PM »
Set you high limit shut off at 200 bring your low limit to 175 with a 10 degree differential, that's how I would set it.
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
Woodboiler
  • OWF Brand: Wood Doctor
  • OWF Model: WD8000
« Reply #2 on: January 09, 2015, 09:24:26 AM »
Set your high limit to 190 and the low limit to 175 in the colder times.  Setting high limt at 200 will allow the boiler to overheat the water in the top of the stove and 200' is the factory setting for the 2nd safety aquastat.
Ed
Michigan Wood Boiler repair
Parts and Service
Jwood
« Reply #3 on: January 09, 2015, 01:59:21 PM »
Yes that was the high limit I was talking about redlegs numbers were just different that what most use. Most people talk about their setpoint not their low limit, I should have clarified that the 200 degree was the safety shutoff.
Stihl MS 270c
Stihl MS 461
caper
  • OWF Brand: heatmaster 5000
« Reply #4 on: January 09, 2015, 07:02:55 PM »
one more thing, I would raise your in floor temp to at least 120...90 I think is abit low...
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Cape Breton, Nova Scotia
Canada
aries9245
  • OWF Model: Cl6048
« Reply #5 on: January 10, 2015, 06:14:39 AM »
Is your radiant in slab or staple up und subfloor that will determine your temp settings on your radiant heat..A water temperature range of 120 to 135 degrees is ideal Of coarse depending on your system and heat load.
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
Kubota l4610 tractor
2 sthil farm boss saws
