Author Topic: Hydronic heater for garage  (Read 17277 times)
bucky1399
  • OWF Brand: Johnson
  • OWF Model: Little Jon
« on: January 12, 2015, 07:00:39 PM »
Looking for some advice on heating a 2.5 car garage.  Has anyone installed one of these units from outdoorfurnacesupply?
http://www.outdoorfurnacesupply.com/water-to-air-heat-exchangers/uh50.html
They have a 3 year warranty, compared to the Dragon Breath heater, 1 year.  Dragon Breath is over twice as much.
Also found the Modine H2ot Dawg...for almost a grand...ouch.  Would consider fabricating my own unit, but with the price of the outdoorfurnacesupply unit I would save myself the hassle.  Any thoughts/suggestions?
juddspaintballs
Re: Hydronic heater for garage
« Reply #1 on: January 12, 2015, 08:13:30 PM »
Will 50,000 BTU heat your 2.5 car garage adequately?
bucky1399
« Reply #2 on: January 12, 2015, 08:56:56 PM »
I think so.  Most research I've found recommends 45k for 2.5 car garage.  If I can get the garage to 50-55 degrees for working on vehicles I would be happy with that.
Wood Nutt
  • OWF Brand: shaver
  • OWF Model: 250 Pro, Stihl 660, 290, 210, 031AV, Efco 3500
« Reply #3 on: January 12, 2015, 11:29:40 PM »
I don't have that particular unit heater, but I bought the bulk of my supplies for my original install from outdoorfurnacesupply.  I have had no problems with anything I bought from them and he was very helpful answering questions and making suggestions before and during my build.  If my history is any indicator, I think you will be satisfied.
What this country needs is less dirty minds and more dirty fingernails!
agriffinjd
  • OWF Model: BL 3444
« Reply #4 on: January 13, 2015, 04:40:51 AM »
I bought a 100,000 but unit from badgerinsulatedpipe.com for $291 and it works great on my 30x40 garage with 11' ceilings.  I had free shipping as I also got other supplies to hit $500.  The heater you are looking at is probably the same brand as mine just smaller.  So if it is rated as the size you need then it should work fine.  I have mine hard wired to a thermostat, but I know they sell a plug in thermostat that they said most customers use with it.  I keep my garage right around 60.
U.P. of Michigan
coolidge
« Reply #5 on: January 13, 2015, 01:23:32 PM »
I have two of the 89k btu, only one being used right now, works good.
Western Maine
Bud Man
  • OWF Brand: P&M
  • OWF Model: BL 2840
« Reply #6 on: January 13, 2015, 08:33:32 PM »
Look on craigslist for furnaces. I found a Lennox Pulse made in 1995. The heat exchanger was cracked but the fan was good. I made a "hood" to put on the air outlet and plumbed in a water to air heat exchanger, hooked up a thermostat and I'm heating a 3 1/2 car garage with it. I have $186 and my time in it. Had a "Hawaiian" party in it last weekend. Outside was -3, inside was 91.
Livin' on a long and lonesome highway east of Omaha.
« Reply #7 on: January 14, 2015, 03:30:12 AM »
Way to go Bud Man, I would have been there but my invitation must have gotten lost in the mail
heatthefarm
  • OWF Brand: CB
  • OWF Model: 5648
« Reply #8 on: January 14, 2015, 05:32:05 AM »
Bucky1999,
I have this exact heater in my garage (36 x 26 with 12.6" ceiling) and it does the job. However - it is extremely loud with the fan set up it uses. You might be able to quiet it down by building something around it. I also have big ole cast iron rads that i primarily use for heat- I turn the unit on you are looking at when temps drop below -10.
netwerx-r-us
  • OWF Brand: Tennessee Outdoor Furnace
  • OWF Model: Hoss 400HE
    • Netwerx-R-Us
« Reply #9 on: January 14, 2015, 05:59:01 AM »
I build my own heaters , its pretty simple and they work well , I use them to heat 2 large greenhouses so they would do a garage or shop easily    I buy one 22x22 heat exchanger---176.00 ,   1 Lasko 2265QM 20-Inch Max Performance fan  =75.00   1 thermost --37.00 , build a wood frame 12-14 wide and mount the heat exchanger in it ,mount the fan on backside and  plug the fan into the thermostat and locate the thermostat on other side of room ,
http://www.ebay.com/itm/22x22-Water-to-Air-Heat-Exchanger-Hot-Water-Coil-Outdoor-Wood-Furnace-/191070469563?pt=LH_DefaultDomain_0&hash=item2c7caffdbb
http://www.amazon.com/Lasko-2265QM-20-Inch-Performance-Velocity/dp/B0073CQ9XA
http://www.amazon.com/gp/product/B000E7NYY8/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1
Ive been running these 2 years now, no issues , you can adjust the size of your eat exchanger accordingly but that one there will do it no problem
« Last Edit: January 14, 2015, 06:04:04 AM by netwerx-r-us »
Netwerx-R-Us
http://netwerx-r-us.com
Kubota 3430 W loader and backhoe
Echo 440
Honda Rancher 400
Kubota ZD326
heatthefarm
  • OWF Brand: CB
  • OWF Model: 5648
« Reply #10 on: January 14, 2015, 07:51:14 AM »
I like  that!!!!!!
thanks for the links
bucky1399
« Reply #11 on: January 14, 2015, 01:13:55 PM »
Bucky1999,
heatthefarm-Do you think this unit is enough to heat the garage on it's own?  My garage is 650 sq ft, 9' ceiling?  Any benefit in getting a unit with a multispeed fan?
MerrellRoofing
  • OWF Brand: P&M
  • OWF Model: BL 34-44
« Reply #12 on: January 14, 2015, 03:46:59 PM »
I wish mine had a multi speed fan.
Mid-Michigan
Husqvarna-51-261-372xpg-395xp
Chevy Dually Dumpx2
BoilerHouse
  • OWF Brand: Home Built
« Reply #13 on: January 14, 2015, 04:53:09 PM »
LIke netwerx, I built my own.  Hx size 18 x 18.      A also put an air filter on it since my 24 x 30 garage doubles as a metal/wood work shop.
Muskoka, Ont
Bud Man
  • OWF Brand: P&M
« Reply #14 on: January 14, 2015, 05:53:00 PM »
Slimjim, that's why the mailman was here. He kept your invitation, can't trust anyone.
You let me know when you're coming and I will have another "Hawaiian" party. Or whatever kind of party you want to have.
