Pages: 1 [2]
Author Topic: Should i buy the Pex from my OWB dealer?  (Read 21040 times)
Re: Should i buy the Pex from my OWB dealer?
« Reply #15 on: January 23, 2015, 02:49:52 AM »
Are you saying that the metric pex such as Logstor has a thinner wall, I have never measured it but I think not!
« Reply #16 on: January 23, 2015, 06:15:19 AM »
Not if you make it to have fittings interchangeable with copper. Standard pex is made to copper tubing sizes. They didn't just pull the numbers out of the air.
If they were trying to cheat on the size, they would have made the pipe wall thin like the metric pex.
You kinda lost me on that one, I grabbed a set of calipers and measured both. One inch pex has an ID of .865" while the piece of copper tubing I have in the basement measured 1.030".
« Reply #17 on: January 23, 2015, 06:33:47 AM »
OD is same.
« Reply #18 on: January 23, 2015, 06:38:18 AM »
Yes, it does. It is SDR11. Standard pex is SDR9.
« Reply #19 on: January 23, 2015, 06:39:40 AM »
Gotcha, still rather misleading though as the OD doesn't contain the water.
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
« Reply #20 on: January 25, 2015, 01:18:45 PM »
1¼" Wirsbo hePEX...don't fit CB thermo pex
 id 1.054" >1.054in = 26.772mm
 od 1.375" >1.375in = 34.925mm
 1½" Wirsbo hePEX   use them to fit the  CB thermo  ....it  measures 42mm od,32mm I'd... or there real numbers >
 id 1.244" >1.244in = 31.598mm  *
 od 1.625" >1.625in = 41.275mm   *these last 2 numbers are  CB thermo
« Last Edit: January 25, 2015, 01:20:35 PM by atvalaska »
« Reply #21 on: January 25, 2015, 11:02:10 PM »
So, Central Boiler is selling 1-1/2" pex and calling it 1-1/4"
What is the point of that?
atvalaska
  • 907, no vacancy !
« Reply #22 on: January 26, 2015, 09:35:08 AM »
metric...crap ... I ordered in 1.25 fittings when I got started ..had to order 1.50... and buy the uponor 1.5 head for my tool..
Pages: 1 [2]
