Author Topic: Water Treatment  (Read 7974 times)
JKY
  • Newbie
Water Treatment
« on: November 18, 2010, 01:42:55 PM »
I have resentlly purchaced a use Heatmor outdoor furnace.  The guy I bought it off said I need to add some kind of water treatment to it.  Does anyone know what it is & where to get it?
Russ Brumit
Re: Water Treatment
« Reply #1 on: November 18, 2010, 03:01:25 PM »
Hello, I can get you a gallon of water treatment for 60.00 shipped to you . Will take care of 500 gallons of water . Give me a call if interested.
  Russ 443-907-7455
Shaver  Series 290
443-907-7455
Re: Water Treatment
« Reply #2 on: November 18, 2010, 05:47:21 PM »
I would guess that Heatmore wants you using their own type of water treatment to keep up any warranty that may be left on the furnace. If that isn't an issue I would recommend a water treatment that has been designed for 409 stainless ( the metal used on Heatmore furnaces). Be careful of what kind you use, I have seen some water treatments on the market that are practically worthless. If I were you I would contact a Heatmore dealer to find out what type works best with the furnace. Most furnace companies have had labs design treatment especially for that brand of furnace.
TheCrier
Re: Water Treatment
« Reply #3 on: November 19, 2010, 03:24:09 PM »
For less than $10 you can use water balancers for hot tubs.....
Roscommon
Re: Water Treatment
« Reply #4 on: November 20, 2010, 06:05:02 AM »
Treatment size depends on model size.
Call factory for nearest dealer.
200css is 2 gal
400 css is 2.5 gal.
It is expensive but worth it.
Also check the anode rod.
Where are you at?
Whats the size and age.
