Author Topic: Strainer/Filter  (Read 8515 times)
tinfoilhat2020
  • OWF Brand: POS
Strainer/Filter
« on: February 03, 2015, 08:33:02 AM »
Who is using a Sediment Strainer or Trapper? DO you find them worth the extra $150?? Thinking about adding one in this spring
Thanks
Re: Strainer/Filter
« Reply #1 on: February 04, 2015, 03:06:25 AM »
They are a good idea when they are installed and maintained properly, trouble is that once they are installed, most home owners completely forget about them, Be sure to install a bypass around the filter so that as it plugs up the filter, water can flow around it without restriction.
tinfoilhat2020
  • OWF Brand: POS
Re: Strainer/Filter
« Reply #2 on: February 04, 2015, 03:58:41 AM »
Thanks Slim, makes sense. I was was thinking about putting one in this spring as i have to redo a bunch on my lines anyways bc of my late install in november. Are there any diagrams available for hooking one up with a bypass???
Thanks!
Re: Strainer/Filter
« Reply #3 on: February 04, 2015, 04:02:49 AM »
It's very simple really, put the filter in line with your current piping and install tees on each side of the filter that connect the loop around the filter, ball valves are recommended as well so that the cartridge can be changed without interruption of service
tinfoilhat2020
  • OWF Brand: POS
Re: Strainer/Filter
« Reply #4 on: February 04, 2015, 04:13:34 AM »
ahhh makes sense slim. thank you
Re: Strainer/Filter
« Reply #5 on: February 04, 2015, 02:19:45 PM »
I have Wye-strainers on both sides of all FPHE (when I saw both sides; I mean OWB and closed loop radiant)
Every fall, as part of the maintanence before I fill the water levels back up, I flush some water (and other assorted JUNK) out of the strainers; then top off system and LIGHT THE FIRE
