Author Topic: Sizing a plate heat exchanger?  (Read 18400 times)
Axeman
« on: February 04, 2015, 07:31:11 PM »
We heat our home with a central boiler outdoor stove. Currently we heat our water with an electric water heater. I am looking at getting a plate heat exchanger to heat our domestic water but i have no idea what size i would need.
Any help on this subject is appreciated!
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: Sizing a plate heat exchanger?
« Reply #1 on: February 04, 2015, 07:46:09 PM »
A 20 plate should be sufficient. I think most are around 3.5" x 8"-10". I filled a 400 gallon hot tub and never ran out. I'm plumbed before my tank and the tank is off at the breaker.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
Axeman
« Reply #2 on: February 04, 2015, 08:12:25 PM »
So the plate heat exchangers do not have to be hooked directly into the water heater?
Wood Nutt
  • OWF Brand: shaver
« Reply #3 on: February 04, 2015, 09:42:19 PM »
No, no direct tank connection is required.  I have a 30 plate just to be sure and an electiric demand water heater.  I shut off all of the circuits on the electric demand heater so it is nothing more than a pipe in the winter and I have never ran out of hot water.
Over the holidays we had 9 people staying in the house and the shower ran for probably 1.5 hours+ straight a couple mornings.  if that did not run the plate exchanger at max, not sure what would.
You also need to add a tempering valve after the plate exchanger on the potable water side of to avoid scald potentials at your appliances (sinks, showers, etc).  there are plenty of examples on here if you look around a little on various ways to set this up.
« Reply #4 on: February 04, 2015, 09:52:03 PM »
You will want to get a 5x12" or 5x13" plate.
20 plate will work fine unless you are very near the limits on boiler water flow. If you are, going with a 30 plate will usually work without needing to get a larger pump.
« Reply #5 on: February 05, 2015, 10:49:26 AM »
SIDEARM HEATERS, also work  ;)
Axeman
« Reply #6 on: February 05, 2015, 02:22:09 PM »
Thanks for all the help! Much appreciated.
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
5050racing
  • OWF Brand: CB-1450
« Reply #8 on: February 06, 2015, 07:26:39 AM »
My system is plumbed direct but it pass thru the domestic hot water heat changer from central boiler you will need a mixing valve also to cool water coming out of hot water heater
« Reply #9 on: February 06, 2015, 10:03:08 AM »
To clarify, you have to put a mix/tempering valve on the Domestic hot water line coming out of water heater, other-wise you get 180f to faucet (OUCH).  By the way, you can run un-tempered water to applicances such as Dishwasher and clothes washer, IF DESIRED
kommandokenny
  • OWF Model: 4400
« Reply #10 on: February 06, 2015, 12:31:53 PM »
Yep,, and if you use a small ten plate xch., you won't need a mixing valve, as your water won't get hot. :o
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
« Reply #11 on: February 06, 2015, 01:40:30 PM »
A small 10 plate could. Just not how yours was plumbed. A large plate probably wouldn't have done much better in the same place.
kommandokenny
  • OWF Model: 4400
« Reply #12 on: February 06, 2015, 01:58:00 PM »
Yep your right about that ..
but,,, does anyone on the forum use a small 10 plate by itself, in any configuration.??
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
fireboss
« Reply #13 on: February 06, 2015, 04:41:15 PM »
I heat my pool with a ten plate,  I would use one to heat my hot water, I had my pool up to 95 when I forgot I was heating the pool
kommandokenny
  • OWF Model: 4400
« Reply #14 on: February 07, 2015, 06:31:11 AM »
not without a circulating pump ;D.......[on the domestic ] pool side]
« Last Edit: February 09, 2015, 02:35:46 PM by kommandokenny »
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
