Author Topic: Spray foamed my lines in the ground  (Read 11195 times)
« on: November 27, 2010, 05:09:23 PM »
I'd love to post pictures, but I didn't get any.  I didn't want to hold my buddy up.
I met him a couple weeks ago because we share a common interest in large military vehicles and we both own M35A2's (old school military 6x6 cargo trucks commonly called deuce and a halfs).  We got to chatting about my OWB and the trench I had dug and I told him I was going to spray foam my PEX in the ground.  He told me he's done it several times before and he still had contacts with the supplier his company used.  He contacted the supplier and got me some old tanks of spray foam and then two brand new spray foam tank kits for me for FREE!!!
Yesterday, we decided to start at 7 AM this morning.  At 6 AM I woke up and quickly laid down my 1" PVC electrical conduit and then put the 8' wide 4 mil thick plastic down in a U shape in the trench.  It was 35 degrees out and very windy.  It remained that way the entire day.
We started spraying my 1-1/4" PEX at the house with the old tanks of foam.  It didn't set up well so we stripped it off pretty quickly.  We switched to the first set of new tanks and went to town.  We got about 60' done before those tanks were used up.  We switched to the other new set of tanks and kept going.  We had to stop once during the second set of new tanks to let them warm up again in the house.  The foam set up fine in the 35 degree weather because the two chemicals mixing create an exothermic reaction.  When we were all done, we wrapped the extra plastic around the foamed lines and called it quits.  Took us about 2 hours to do my entire 80' and we put a bunch of extra in the hole through my wall in the house and at the OWB.  I still have about half of the second set of tanks left including a brand new set of hoses and nozzles.  I'm sure I can find stuff around the house to spray as well.
It pays to know people!  ;D
If you really want a picture, I can go snap a picture of the foam wrapped up in a blanket of plastic about 3' down in the dirt.
Smakman
Re: Spray foamed my lines in the ground
« Reply #1 on: February 05, 2011, 06:24:43 PM »
 I have been researching my own install and came up with this very idea myself!  So how has it worked out for you?  I have a friend that has his own spray foam insulation business so I can do this very inexpensively (like you said, it pays to know people, lol).
Smakman
« Reply #2 on: February 05, 2011, 06:26:29 PM »
Oh, and BTW.....it appears that we share some other interests as well.  I also own a M35A and......a paintball field.
jackel440
« Reply #3 on: February 05, 2011, 06:52:35 PM »
I want to come over and drive your truck,and shoot people with paint balls!hahahaha ;D ;D
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
Smakman
« Reply #4 on: February 05, 2011, 07:14:38 PM »
No problem!  Bring your Stihls........we will cut a few truck loads of firewood while we are at it, lol.
« Reply #5 on: February 06, 2011, 11:23:11 AM »
I get a 0.2 degree drop in temperature over my run when my house isn't calling for heat.  And that's with the radiator in the basement still heating and my water heater being heated.  When the house is calling for heat, I get about a 10 degree difference between supply and return.  This is measured by my digital well thermometers.  Also, no snow melt on the ground over the PEX lines.  I think the spray foam worked out well.
Paintball and deuces?  I'm down for that.  I'll bring mine.
Smakman
« Reply #6 on: February 06, 2011, 09:16:42 PM »
I figure on using closed cell.
