Author Topic: Possible to damage boiler from throwing wood into firebox?  (Read 12893 times)
hrc200x
When I put wood in the boiler an occasional piece will slide on the other logs and hit the back of the boiler, and other times they will stop dead and I'll have to use my hand, foot, or ash rake to push the log in. Has anyone ever seen any damage to a boiler thats had wood thrown in it? I'm assuming it would take many years of doing this before it was a issue. It probably helps that there is water behind the steel to help absorb the blow.
Re: Possible to damage boiler from throwing wood into firebox?
« Reply #1 on: March 02, 2015, 08:57:59 PM »
Depends on the boiler, some of the stainless ones that used 10 gauge or thinner for the firebox could be damaged, if a 1/4" mild steel one could be damaged it was either a subpar weld or was getting thin anyways. I built mine out of 5/16" and still avoid chucking wood in.
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
« Reply #2 on: March 03, 2015, 07:23:50 AM »
I try toss smaller, lighter, sticks, to the back,, then push them home with a long shovel.
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
userdk
  • OWF Brand: Heatmaster SS
  • OWF Model: G 400
« Reply #3 on: March 03, 2015, 03:20:04 PM »
Not usually a problem. It'd have to be a bad weld.
BeaconWoods
  • OWF Brand: Wood Doctor, Portage and Main
  • OWF Model: WD 8000, BL 3444
« Reply #4 on: March 03, 2015, 04:55:10 PM »
I've had the same question.  I feel kind of sorry for the unit when I hit the back wall.  Kinda strange I suppose.  Anyway, I try not to do it.  Mine did spring a leak at the bottom of a transfer tube at the back of the unit.  Don't know if that's a direct result or not.  It's the 5th or 6th (and last ever) leak this thing has sprung.
real bill
  • OWF Brand: global hydronic
  • OWF Model: GH-2000
« Reply #5 on: March 03, 2015, 06:53:02 PM »
I know the feeling of when I toss a stick a little to hard and it hits the back of the firebox, I think it's a sickening  sound for sure.  I don't think hit hurts once in a while.
tawilson1152
  • OWF Brand: Crown Royal
  • OWF Model: 7300
« Reply #6 on: March 04, 2015, 03:16:40 PM »
It usually stops my blower soleniod from buzzing.
kommandokenny
  • OWF Model: 4400
« Reply #7 on: March 04, 2015, 03:19:23 PM »
nice :thumbup: :thumbup:
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
« Reply #8 on: March 04, 2015, 09:28:12 PM »
/sigh
a buzzing solenoid doesn't mean a thing unless it's right next to your bedroom window. Solenoids will vibrate 60 times a second unless you're in a country that uses 50 hertz then it's 50 times a second. Mines been buzzing since day one, that was almost fifteen years ago. While annoying, it doesn't indicate pending solenoid failure.
woodywoodchucker
  • OWF Brand: cental boiler
  • OWF Model: classic 5036
« Reply #9 on: March 05, 2015, 04:04:05 PM »
When I got my 5036 i was told that I could and should burn 30"/36" wood.When throughing those in aand hitting the back of the boiler. Thought this cant be good for anything. Over the past few years ive found that 18/22" wood works better and acually burns longer.
walkerdogman85
  • OWF Model: H-4
« Reply #10 on: March 05, 2015, 04:35:24 PM »
Same here I can burn 30" stuff and as big as the door but for the most time I burn shorter smaller stuff. Much easier on me and I don't have to shove huge pieces in causing the walls on my hardy to dent or rupture..
Michael West
Central Ohio
Amankman
  • OWF Brand: Ridgewodd
  • OWF Model: 6000
« Reply #11 on: March 06, 2015, 05:47:11 PM »
/sigh
I've found that fine sand paper or emry cloth ran where the solenoid makes contact quiets it right down!
Ken A
Thumb of Michigan
tawilson1152
  • OWF Model: 7300
« Reply #12 on: March 06, 2015, 06:51:19 PM »
Mine rattles at the pin that connects the damper to the solenoid. No biggy.
ijon
  • OWF Brand: Portage and main
  • OWF Model: 28-40
« Reply #13 on: March 08, 2015, 04:46:34 AM »
Get the traps the rats have crawled back in.
installed in 2014
