Pages: 1 [2] 3
Author Topic: ADD EXTRA PUMP??  (Read 20898 times)
Bondo
  • OWF Brand: Home built
  • Master General Re-Engineer
Re: ADD EXTRA PUMP??
« Reply #15 on: March 16, 2015, 04:53:43 PM »
I agree -> KISS, is the way to go
As long as you have a back up pump available, i.e. on the shelf you should be fine.  BTW, why travel when its -40 c/f that is too cold to be outside
Definitely too cold to change a pump....... ;D
Fingers would fall off.!!
Ayuh,....    Is the plumbin' in the house, as low, or lower than the bottom of the boiler,..??
You can put yer pumps Inside, 'n not have any on the boiler,...
Warm hands changin' it,...     ;)
« Reply #16 on: March 16, 2015, 05:19:51 PM »
You can put a 2nd pump in series for a backup and it doesn't cause that much restriction. Water flows through fine when it is off.
You could put a strap on aquastat on it so it only runs when the water line cools. If you put it on the return line it could even be set to come on if you have big temperature drop under load.
« Reply #17 on: March 17, 2015, 04:22:26 AM »
Good answer RSI, I was thinking the same thing!
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
« Reply #18 on: March 17, 2015, 07:15:47 AM »
Thanks guys. :thumbup:
My next concern would be if one of the inline pumps seizes would it restrict the flow enough to make the whole excercise not worth doing.
Gotta look at the pump internals.
Bondo, I like the idea of the pump on the back of the boiler.
And I still want a backup pump in the basement.
Only thing stopping me is flow issue from seized impeller???????????
Gonna look for schematic.of taco 011
kk
« Last Edit: March 17, 2015, 07:17:18 AM by kommandokenny »
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
« Reply #19 on: March 17, 2015, 03:06:42 PM »
Unless todays pumps are not what they used to be, I think you're getting worried over something that could never happen.
15 years on my original Grundfos. But like I said, maybe even Grundfos is not as good as they were?
« Reply #20 on: March 17, 2015, 03:45:23 PM »
Water quality can make a big difference on how long a pump lasts. Some go out way sooner than that.
Water will still flow through the pump ok even if it was frozen up. Something with the type impeller like Grundfos uses would be better for the pump that is not normally running. The type of impeller that Taco uses will probably cause more restriction. 1st pic is Taco, 2nd is grundfos.
« Last Edit: March 17, 2015, 03:47:00 PM by RSI »
kommandokenny
  • OWF Model: 4400
« Reply #21 on: March 17, 2015, 04:59:46 PM »
Thanks,, that's what I wanted to hear.
If the impeller is seized stiff, water can still be pulled through by a second pump down line.
I'm probably gonna do it.
It's like having an extra pump on the shelf.
Who doesn't recommend that??
It's already hooked up,,, and ready to roll.
Thanks rsi
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
Bondo
« Reply #22 on: March 17, 2015, 05:38:52 PM »
Thanks rsi
Ayuh,....    The only thing I'll add is,....    Over the last few years, since I discovered 'em,....
I've switched out my pump flanges to the ones with the built-in ball-valve,....
Changin' a pump is a breeze, with maybe a cup of lost water,...
No more system drainin', just to swap an entire pump,....
kommandokenny
  • OWF Model: 4400
« Reply #23 on: March 18, 2015, 06:52:39 AM »
No draining to replace the cartridge. [at the boiler anyway]
https://www.youtube.com/watch?v=E0X8m0BGZ1g
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
woodbutcher
  • OWF Model: MF10000e
« Reply #24 on: March 18, 2015, 08:16:31 AM »
When I installed my owb 15 years ago, the dealer told me to put the pump in the basement. He said that if it goes out it won't be when the temp is in the 30's. I did and never regretted it. I did have a Y strainer in the line before the pump and the cartage went out almost once a year. Dealer told me to remove it and keep the pump running year around. Since I did this, the pump has never died in the last 4 years running non stop with no filter.
kommandokenny
  • OWF Model: 4400
« Reply #25 on: March 18, 2015, 09:07:21 AM »
The restriction by the strainer burned out the pump??????
This is interesting...
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
« Reply #26 on: March 18, 2015, 09:13:19 AM »
Most likely it did. These pumps can not have negative pressure on the inlet if you want them to last very long. That it the reason it is usually better to put at the back of the stove. In the house works ok as long as water flows to it without it needing to suck.
kommandokenny
  • OWF Model: 4400
« Reply #27 on: March 18, 2015, 11:43:51 AM »
Once again, thanks for that . :post:
So leave taco 011 on the back of the stove and could I put a smaller gpm,,  less restrictive,, Grundfos in the basement unplugged and ready?
[Suggestion for second pump]
It ciculates fine now,, so just for backup?
kk
« Last Edit: March 18, 2015, 11:50:49 AM by kommandokenny »
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
« Reply #28 on: March 18, 2015, 11:48:39 AM »
It depends on what you have in your system. A Grundfos 15-58 should work fine but if you want it to be able to run for a fairly long time till you would get around to swapping the other, you may want to just go with a 26-99 since they can be found cheap right now.
kommandokenny
  • OWF Model: 4400
« Reply #29 on: March 18, 2015, 11:52:15 AM »
Martin says they last 15 years ........
even I would get it changed by then :bag:
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
Pages: 1 [2] 3
