Author Topic: Grounding?  (Read 16572 times)
mootsko
  • OWF Brand: Portage and main
  • OWF Model: Bl 2840 shaker grate
Grounding?
« on: March 16, 2015, 10:28:16 AM »
How many of you out there have your stove grounded to a grounding rod?
It's the my first winter with the 2840 and looking over my owners manuel I see there is a bolt on the tank to ground it. For some reason I can't find it on mine.
Madison Ohio
Crow
  • OWF Model: BL 28-40
  • Eastern Ontario
Re: Grounding?
« Reply #1 on: March 16, 2015, 10:38:55 AM »
Mootsko, I have mine grounded with that ground mentioned in the manual. On mine it is in the rear on the flange where the tank and firebox meet on the right side and it is just a nut on a stud. You may have to move the insulation a little to see the fasteners on the flange.
mootsko
Re: Grounding?
« Reply #2 on: March 16, 2015, 10:58:13 AM »
Ok.  Thanks. I'll give it a little better look.
Do you got a rod pounded in the ground?
Madison Ohio
Crow
  • Eastern Ontario
Re: Grounding?
« Reply #3 on: March 16, 2015, 05:36:12 PM »
 Yes I put a rod into the ground and used 6 gauge copper wire.
Uponthehill
  • OWF Model: 250 & 461 Stihl
Re: Grounding?
« Reply #4 on: March 18, 2015, 03:31:46 PM »
I did the same. 6' ground rod, #6 solid copper wire.
oaky
  • OWF Model: BL-2840
Re: Grounding?
« Reply #5 on: March 18, 2015, 06:23:32 PM »
I'm sorry, but what is the reason for grounding the furnace? My electrical lead in cable has a ground wire that is grounded to the furnace.
Husqvarna 272
Husqvarna 55
27 Ton Cub Cadet Log Splitter
fireboss
Re: Grounding?
« Reply #6 on: March 18, 2015, 06:42:19 PM »
For a possible  lighting strike!
Crow
  • Eastern Ontario
Re: Grounding?
« Reply #7 on: March 18, 2015, 07:00:26 PM »
As I am not an electrician or pretend to be, here is my reason for grounding it this way. The manual with the furnace shows where to ground it and why. IF/WHEN I have a problem with my stove I don't want a missed step with install to be a reason to not get assistance from the factory.
Re: Grounding?
« Reply #8 on: March 19, 2015, 06:19:13 AM »
Getting hit by lightning is very unlikely, however having stray voltage for whatever isn't, the separate grounding rod should take care of that, also water and metal combined with stray voltage does some weird things.
Cabo
  • OWF Brand: P & M
Re: Grounding?
« Reply #9 on: March 19, 2015, 05:35:02 PM »
If you can't find/don't have a grounding lug on the boiler just install a water pipe ground clamp on one of the supply/return nipples and connect to a ground rod. Inexpensive protection.
rickldb22
  • OWF Model: BL 2840
Re: Grounding?
« Reply #10 on: March 20, 2015, 12:23:26 PM »
I drilled a hole in one leg and grounded it there.
Singlemalt
Re: Grounding?
« Reply #11 on: April 26, 2015, 10:49:13 AM »
Circulating water will create an energy field.  Static electricity????
The grounding would help disperse this.
Kioti DS 4110 HS, Metavic 1150 log loader
Wallenstein FX 90 winch
Husky 257, 359, 346XP chainsaws
Ontario, Canada
schoppy
Re: Grounding?
« Reply #12 on: May 04, 2015, 11:31:54 PM »
Jut an FYI, you should have your unit grounded to your power supply ground wire which would be tied in to your buildings service entrance grounding circuit. If this is done than you can add another ground rod and conductor (#6 copper minimum) to the stove. If the two are not tied together you have the potential to set up a voltage difference between the two grounding circuits which would also be an electrical code violation. There are never any guarantees for lightning strikes but this is what is also required for CSST gas piping systems in a home with a few other stipulations.
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
Re: Grounding?
« Reply #13 on: May 05, 2015, 05:11:43 AM »
Good post schoppy!
Re: Grounding?
« Reply #14 on: May 05, 2015, 09:37:50 PM »
if you ground stove to earth and it is grounded through your electric supply and if your stove is hooked to your domestic water supply it will be bonded there as well. here in Ontario your water line must be bonded to your electrical supply and your gas line must be bonded as well
