Pages: 1 [2]
Author Topic: Heatmor 200ss dropin at year 19  (Read 19807 times)
Re: Heatmor 200ss dropin at year 19
« Reply #15 on: May 05, 2015, 06:45:59 AM »
You guys that have repaired 409, any need to preheat or anneal when finished?
Can’t find it know but came across some data that recommended preheating/annealing 409, of course they could have been referring to the manufacturing of car exhausts where the temperature fluctuations are much greater.
shepherd boy
  • OWF Model: C375
« Reply #16 on: May 05, 2015, 06:17:32 PM »
I am no pro so someone else can give you better advice, but last I used was 308L trimix gas(90%heilum, 7.5%argon, 2.5%carbon dioxide). Never worried about preheating etc. But again I'm not a pro.
Let the youngin's have it
 Gettin' old and lazy
heat550
  • OWF Brand: Heatmor
« Reply #17 on: May 08, 2015, 12:47:34 AM »
Something crazy my suitcase style Lincoln 175 plus 220amp says it can weld stainless 409 10 gauge with 308 wire states on there website .  I'm sure 309 309l work also 98 argon/ 2 % oxygen . its a mig welder . Now find someone that's tried it .  Not a word about preheat . But im still researching.
Heat550
heat550
« Reply #18 on: May 08, 2015, 12:58:29 AM »
... has anyone else cracked the 200 cord oak threshold.
The old mans stove is only about 4 years old and his usade is has been as follows:
2012 - 10 cords (only heating detached 4000sf garge)
2013 - 12 cords (only heating detached 4000sf garge)
2014 - 23 cords (Heating house and garage, and burning a ton of junky poplar and birch, and super cold here in MN last year)
2015 - 16 cords (Addded a side arm heater, so fire will never go out now)
I am thinking he will get to the 200 cord mark soon enough
:) your on your way :)
Heat550
« Reply #19 on: May 08, 2015, 06:42:12 AM »
Heat550
Like I said, came across it once where it said preheating/annealing was the recommended way to weld 409, haven’t seen it since either. I didn’t do that on the 409 tubing I used in my waste oil boiler, but I also used a $23/pound wire that was for joining 409 to dissimilar stainless or mild steel.
WB Guy
  • OWF Model: 200CSS
« Reply #20 on: May 27, 2015, 01:59:14 PM »
I have only used 309stick in the field to weld 409 but in the shop i would use 309 wire in a mig as long as it is acontroled environment. ie no wind.
heat550
« Reply #21 on: August 19, 2015, 03:14:03 AM »
Heat550
Came across this local guy that welds stainless .
Have you ever heard if welds gets to hot it burns the nickle out and it basically turns them hot spots to mild steel ?
might be why if they fail its always at a weld joint .   :o
Heat550
heat550
« Reply #22 on: August 19, 2015, 03:18:09 AM »
Heat550
WB Guy
  • OWF Model: 200CSS
« Reply #23 on: August 23, 2015, 07:11:48 PM »
I have not heard that ?? I will ask some of the mill guys I know and see if that could be the case .. thanks
Pages: 1 [2]
