Author Topic: Leaking push type fittings  (Read 9435 times)
schoppy
« on: May 03, 2015, 12:11:51 AM »
Has anyone had problems with push type fittings (any brand like shark bite, etc.) leaking when the boiler cools down such as when shutting it down for the season?
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
Re: Leaking push type fittings
« Reply #1 on: May 04, 2015, 09:45:55 AM »
easy together = easy apart ...uponor ! :)
Singlemalt
  • OWF Model: BL 2840
« Reply #2 on: May 04, 2015, 11:25:34 AM »
Mentioned shark bite fittings to my portage and main dealer and he wasn't recommending them.
Said they tend to leak.
Kioti DS 4110 HS, Metavic 1150 log loader
Wallenstein FX 90 winch
Husky 257, 359, 346XP chainsaws
Ontario, Canada
« Reply #3 on: May 04, 2015, 11:35:16 AM »
With a push-to-connect, if you remove a connection you typically have to cut back a few inches to get to fresh pipe for the re-connect to onto.  I at least think that is the preferred method
BTW, I agree with atvalaska -> UPONOR ;)
« Reply #4 on: May 04, 2015, 04:01:23 PM »
From what has been mentioned here over the years, Sharkbite brand are pretty good but most others leak. Watts brand push fittings seem to be about the worst.
I have heard that Copperhead brand are good too but I don't use any push fittings.
racnruss
« Reply #5 on: May 04, 2015, 07:54:10 PM »
can't remember the brand they were, but I tried a couple on my initial setup and they leaked pretty soon.  Took them out and replaced with clamps, no problem since.
schoppy
« Reply #6 on: May 04, 2015, 11:17:46 PM »
Thanks everyone for the input. My Portage and Main dealer recommends and uses compression fittings but a friend from church uses and recommends the crimp ring style. I am wondering if any certain type has more flow restriction than another style as the least restrictive would seem to be the best to me (assuming no leaks of course).
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
« Reply #7 on: May 05, 2015, 06:29:44 AM »
Easiest way to tell would be to take the various styles/brands and measure the ID of them , the smaller the ID the more restriction. Of course though, being only and inch or so, the water will just temporarily speed up thru the smaller section, so unless you have an obscene amount of connections in your pex a few thousands between different style/brand fitting shouldn’t add up to a whole lot. On one of my circuits I have a total of four connections on the Logtor then it goes to copper with long radius elbows, when I’m done the house circuit will also be all copper with long radius elbows.
schoppy
« Reply #8 on: May 13, 2015, 09:38:00 PM »
Thanks mlappin.
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
« Reply #9 on: May 13, 2015, 09:59:45 PM »
The crimp fittings are all fairly close to the same inside. The straight adapters are equivalent to about a foot of pex and the elbows are equivalent to 10' of pex.
If you use the expansion type they are larger inside. You are supposed to only use them on pex A.
I have seen them on pex B and pex C and they worked fine but I would stay with approved fittings for the type pex you are using.
schoppy
« Reply #10 on: May 14, 2015, 10:41:41 PM »
I agree with staying with the correct pex crimp for my pipe. I was looking at using the crimp to sweat adapters with long radius elbows for best flow because the crimp elbows look like they would restrict flow more.
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
« Reply #11 on: May 14, 2015, 10:44:23 PM »
Sioux Chief makes a long radius pex crimp elbow but I am not sure where you can buy them. Menards might be able to special order them. I should ask next time I am there.
« Reply #12 on: May 15, 2015, 06:36:08 AM »
 :post:
« Reply #13 on: May 15, 2015, 06:37:57 AM »
Go here and click on you’re state to find a distributor.
http://www.siouxchief.com/connect/find/find-a-distributor
