Author Topic: Flushed FPHX  (Read 6397 times)
Flushed FPHX
« on: May 05, 2015, 05:54:40 AM »
Hi all, A couple of weeks ago when I shut down my OWB, I back flushed my FPHX that separates the pressurized system in the house from the non-pressurized system outside while the FPHX was still hot.  The non-pressurized side was nice and clean (I used Central Boiler's corrosion inhibitor in the OWB)with the vinegar flushed through it.  But, when I ran the vinegar through the pressurized side; man, I couldn't believe the junk that came out of that thing!  After I ran the vinegar through it I ran clean water to flush out the any residual vinegar left behind.  I then ran the vinegar a second time through the pressurized side and this time it was clean.  I ran the pump for about 10 minutes with the vinegar and water flush.  Now the question is; is it normal that the pressurized side of the FPHX be "dirtier" than the non-pressurized side?  Thanks, Roger
Re: Flushed FPHX
« Reply #1 on: May 05, 2015, 06:10:33 AM »
Depends on how old the system is Roger, remember it probably has never been flushed, lower water volume in that side and a lot more piping.
Re: Flushed FPHX
« Reply #2 on: May 05, 2015, 06:14:46 AM »
 ;D Now you may see why Sediment or Wye filters are HIGHLY recommended on the inlets to FPHE.
...which reminds me, I need to clean out my wye filters  :thumbup:
Re: Flushed FPHX
« Reply #3 on: May 05, 2015, 07:56:45 AM »
Thanks for the reminder, I need to clean my wye filters too.  Roger
