Author Topic: wood consumption for a 10,000 e  (Read 8875 times)
caper
  • OWF Brand: heatmaster 5000
« on: May 09, 2015, 12:45:59 PM »
Hello guys, quick question for anyone still online, I have a 5000 mf, and considering a new 10,000e, so will the wood consumption be the same for the bigger unit, I currently burn approx. 12 cord of hardwood per year, will the bigger unit burn the same amount or will it burn more, heres wishing for less....
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Cape Breton, Nova Scotia
Canada
AirForcePOL
  • OWF Model: G400
Re: wood consumption for a 10,000 e
« Reply #1 on: May 09, 2015, 05:01:08 PM »
Your wood consumption should stay about the same if your demand won't be increasing.  You will still require the same amount of energy to do what your current stove already does.  You will have a huge difference in your burn times though as a 10k has twice the capacity as a 5k.  With the furnace not cycling as much I guess it's possible that you could end up using less wood.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
AirForcePOL
  • OWF Model: G400
« Reply #2 on: May 10, 2015, 09:29:47 AM »
I just realized you have a standard 5000.  Moving to an E model will help some on your usage also.
Athens, Illinois
Stihl MS 290
shepherd boy
« Reply #3 on: May 10, 2015, 01:26:08 PM »
You should burn 25% less with an E model even less with a C model but a C has its own character. It's  exhaust is so cool you must keep good airflow and no chimney extension to make it run clean.Know people that say they burn half the wood with a C model but there may be other factors involved.
Let the youngin's have it
 Gettin' old and lazy
caper
« Reply #4 on: May 12, 2015, 05:02:40 PM »
thanks for the input guys, all very interesting...
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Canada
TheBoiler
  • OWF Brand: Garn
  • OWF Model: WHS2000
« Reply #5 on: May 14, 2015, 12:56:21 PM »
If the unit is oversized it will smoulder longer and efficiency will take a nose dive.
Hot and hard is the most efficient.
AirForcePOL
  • OWF Model: G400
« Reply #6 on: May 14, 2015, 02:52:12 PM »
I feel that would be big factor with a gasser.  With a conventional, if it's only loaded enough to get by for 12 hours or so he should be fine.  I think the benefit of the added capacity on the really cold nights will out way longer idle times.
Athens, Illinois
Stihl MS 290
