Author Topic: What type of spray foam?  (Read 7494 times)
big cat
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-175
« on: May 29, 2015, 07:58:42 PM »
So I've decided to give my NC-175 one last shot before replacing it, albeit with one change. I plan on replacing the batt insulation with spray foam insulation. Any suggestions on what type of foam I should use?
Thanks.
juddspaintballs
Re: What type of spray foam?
« Reply #1 on: May 29, 2015, 09:03:52 PM »
Closed cell
coolidge
« Reply #2 on: May 30, 2015, 10:39:46 AM »
Closed cell for shure, MINIMUM 3"
Western Maine
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
« Reply #3 on: May 30, 2015, 10:42:24 PM »
why is 3" the number   ?  ... 3" of foam has a higher  r valve ...then any batt/foil ins like we/i l have  I plan to do the same tho....
coolidge
« Reply #4 on: May 31, 2015, 06:28:15 AM »
3" will give you greater compression strength. It will take the place of the outer "black sleeve" others use.
Higher R value too of course.
Western Maine
nstueve
« Reply #5 on: June 10, 2015, 08:34:06 AM »
I've been looking at the same thing. Closed cell is def the way to go however can you get closed cell to install yourself somewhere? Seem like the DOW Froth Pak's are 200sqft of 1" thick and are $300! Are they even closed cell? Seems like 3" of spray foam could cost you $600+ to insulate...????
Too many chainsaws to list...
5hp NT splitter
OWB soon???
juddspaintballs
« Reply #6 on: June 10, 2015, 12:19:45 PM »
Yup, it's not cheap.
