Author Topic: Has anyone installed runners on the legs of their heatmaster?  (Read 6905 times)
stewie3500
  • OWF Model: C375
I have just purchased a C 375 and am looking at options to unload the stove and move it around to its resting place. The trailer it is on has a ramp and i have used it to move my previous stove from trailer to pad, and back to trailer when i sold the stove. I am have envisioned 3" angle iron welded on the feet in place of the small pads that are factory installed. The runners would be the full length of the stove for stability. I would cut reliefs in the ends of the angle and bend them upward with heat to form raised ends. This would enable me to drag the stove behind the tractor around the yard and up on the pad. I do realize that the stove was designed with the ability to be transported by pallet forks and by overhead lift but i dont have the means to utilize either option, i am able to fabricate and the steel is available.
Ram 4500 C&C
Load Trail 14k dump trailer
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
Re: Has anyone installed runners on the legs of their heatmaster?
« Reply #1 on: July 04, 2015, 11:58:58 AM »
Sounds like a lot of work but you gotta do what you gotta do.
AirForcePOL
  • OWF Model: G400
« Reply #2 on: July 04, 2015, 01:05:00 PM »
I think it would work but I would be worried it would fall over when you went down the ramps.  Do you have a big tree or something you could use to lift the stove up and off the trailer then rig something up to drag it into place?  Is there anywhere that you could rent a machine from for a few hours?  I agree with slim it sounds like a lot of work.  Got any neighbors with a machine that will work for a few cases of beer?
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #3 on: July 05, 2015, 04:10:14 PM »
Your delivery driver might not be patient enough for all that fabrication. Can your local rental store and get a Lull for two hours. I used the back end of a backhoe for my 10k and it almost wasn't enough.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
« Reply #4 on: July 05, 2015, 07:06:26 PM »
Thats a pretty stout backhoe…..
stewie3500
  • OWF Model: C375
« Reply #5 on: July 05, 2015, 10:00:57 PM »
I picked the stove up from the dealer. No delivery driver involved. I removed the pads from the legs after placing 4 jack stands under the frame. Then, I welded runners to the legs. I placed plywood on the ramp of the trailer and used the three point hitch on the tractor to raise the front of the trailer up. This eliminated the sharp angle between the floor and the ramp
The stove is unloaded and on the pad.. Tomorrow I will sand, prime and paint the runners. It worked very well and only cost me a couple hours and a few marks in the yard. Grass grows back. Thanks for all the suggestions.
Ram 4500 C&C
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
CountryBoyJohn
« Reply #6 on: July 06, 2015, 09:16:38 AM »
Looks great!  Good luck with your new Heatmaster!  You'll love it!
Stihl MS290
Woodchuck Log Jack
Knox County, IN
stewie3500
  • OWF Model: C375
« Reply #7 on: July 06, 2015, 05:44:35 PM »
Thanks Countryboy, it is a very nice stove. When the pumps come in I will start plumbing. I am looking forward to fall. I am rebuilding a gravity wagon to store coal in.
« Last Edit: July 07, 2015, 05:08:57 PM by stewie3500 »
Ram 4500 C&C
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
