Author Topic: How much electricity does a pump use  (Read 12027 times)
Jared43758
  • OWF Model: C250
« on: July 07, 2015, 06:45:54 PM »
I have a bell and gusset 3 speed pump running it on speed 2. Running constantly how many Kw does it use a day or month or hr.  I pay around 7.3cents/kW
Stihl MS290
Stihl MS660 Magnum
Husky 21 ton splitter
Southeast Ohio
Re: How much electricity does a pump use
« Reply #1 on: July 07, 2015, 07:53:57 PM »
You should be able to goto B&G’s website and find a chart.
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
« Reply #2 on: July 07, 2015, 10:29:08 PM »
who cares ...I spend near .26 a kw ....at .7 I would own the world ! :) ...get a kill-a-watt from the library...
Chas
« Reply #3 on: July 08, 2015, 04:07:53 AM »
Depends on which model Bell and Gossett you have. I run an NRF-25 to the shop and an NRF-36 to the house. Both are 3 speeds. The 25 is a 1/15th HP and the 36 is a 1/6th HP.
Dolmar 035
Stihl 026
Stihl 260
Speeco 25 ton splitter
John Deere 4720
Polaris Ranger 800
Jared43758
  • OWF Model: C250
« Reply #4 on: July 08, 2015, 12:30:40 PM »
It's a NRF-36 pump. 1/6 hp
Stihl MS290
Stihl MS660 Magnum
Southeast Ohio
« Reply #5 on: July 08, 2015, 11:09:32 PM »
It is best to use a watt meter to see what you are using. The actual power usage will vary depending on what the head pressure of your system is.
With your power rate, I would guess it is costing about $10 per month.
shepherd boy
« Reply #6 on: July 09, 2015, 03:49:12 AM »
I think you will find that pump pulling about 200 watts on high so less on 2nd speed. 200x 24=4800 watts 115 volts per day. Houses are computed at 230 volts so divide in half =2400 watts -2.4 kw=17.76 cents per day x 30 days =$5.33. Constant run pumps pull less than a pump a pump that starts and stops often. Starting a electric motor under full torque takes watts. 2nd speed will take less watts because you are not trying to  pull as much head or gpm. Correct my computation if I'm wrong. Nice little early morn brain teaser.
Let the youngin's have it
 Gettin' old and lazy
« Reply #7 on: July 09, 2015, 03:51:00 AM »
I'm going to trust your ability, I've seen what your brain can do with wiring!
« Reply #8 on: July 09, 2015, 05:33:20 AM »
Compared to what it cost us in LP then later Nat gas I figured running a pump or two was practically free.
« Reply #9 on: July 09, 2015, 05:33:50 AM »
Compared to what it cost us in LP then later Nat gas to heat the house and DHW I figured running a pump or two was practically free.
« Reply #10 on: July 09, 2015, 04:35:58 PM »
I have these numbers on that pump written in my note book (I must have found this on the web for what that is worth)
high speed - 230 watts, medium speed - 190 watts and low speed - 135 watts
« Reply #11 on: July 09, 2015, 04:40:33 PM »
Voltage has nothing to do with wattage so you should not divide in half. You need to double your estimated price or recalculate with 4.8KW per day.
« Reply #12 on: July 09, 2015, 06:55:08 PM »
they wouldn't use half the watts they would use the same amount. if a 115 volt pump used 10 watts then a 220 volt pump would use 5 watts on each hot wire = 10 watts
« Reply #13 on: July 09, 2015, 06:55:43 PM »
A 115v pump will use the exact same watts as a 230v pump.(same model pumps) The 230v one will use half the amps though which has nothing to do with the cost to run it.
« Last Edit: July 09, 2015, 06:57:49 PM by RSI »
« Reply #14 on: July 09, 2015, 07:02:55 PM »
You beat me to it.
5 watts on each wire is sort of right but not really. It is still a single circuit. You could say the 115v pump uses 5 watts on the hot and 5 on the neutral which is the same thing. Also, if you have a 230v hot and a neutral it will run just the same as normal 2 hots line power.
