Author Topic: Needing a fire at night  (Read 8494 times)
jmyers8
  • OWF Brand: ridgewood
  • OWF Model: 6000
« on: September 29, 2015, 08:47:08 AM »
This is my first year with my ridgewood 6000 and it looks like next week some lows in the 40s then back tonthen60s during the day. What do you guys do when you need a fire at night but none during the day do you restart it every time or keep a small one going threw the day.
Pointblank
  • OWF Model: Classic Edge 550
Re: Needing a fire at night
« Reply #1 on: September 29, 2015, 06:24:31 PM »
I just use the propane furnace for what little heat is needed in early fall. Its usually mid to late October before I fire up the stove
Minnesota
oaky
  • OWF Model: BL-2840
« Reply #2 on: September 29, 2015, 07:24:22 PM »
When I know it's going to get above 60 and there is some coals left from the previous night, I'll put in a very small amount of dry wood for the day, enough to carry the burn, until the evening fill.
Husqvarna 272
Husqvarna 55
27 Ton Cub Cadet Log Splitter
Pit Crew
  • OWF Brand: Centeral Boiler
  • OWF Model: 6048
« Reply #3 on: September 30, 2015, 01:20:55 PM »
How do you keep the house from getting too hot during the day? Canyou shut the pump off during the day or is that a bad idea?
North east Ohio
Since 1960
oaky
« Reply #4 on: September 30, 2015, 02:32:57 PM »
Never shut your water circulator off while there is any amount of wood left, including hot coals. Water temperature will rise quickly even with some glowing embers left. What I do is turn down the water temp way down, down to 150 degrees so the draft blower won,t kick in.
Husqvarna 272
Husqvarna 55
BoilerHouse
  • OWF Brand: Home Built
« Reply #5 on: October 01, 2015, 08:41:58 PM »
I usually burn a bit of oil for the first 2 or 3 weeks of the heating season but if I where to use the boiler I would make a fire in the evening.
Muskoka, Ont
« Reply #6 on: October 01, 2015, 09:18:14 PM »
It is best to put in a bypass valve if your house is getting too hot on warm days. That way you can still heat the DHW.
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
  • Southeast Michigan
« Reply #7 on: October 02, 2015, 02:04:39 PM »
A bypass is a good idea and works great but don't you guys have thermostats hooked up in your homes?
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Stihl 036pro, 362c, 064
Husk 385,570
Shindiawa 416
Griffin 14' Dump
Pointblank
« Reply #8 on: October 02, 2015, 06:40:22 PM »
Even without the thermostat calling for heat, just having 180 degree water circulating through the furnace plenum will dump a fair amount of heat within the home. You don't notice it on cold days, but warm days we sometimes need to open a window unless the bypass is used.
Minnesota
« Reply #9 on: October 02, 2015, 07:19:47 PM »
Same here, on days when its in the upper 50’s or low 60’s the house can get too warm with 180 degree water circulating thru the lines. Wife is always home thou so she just opens a few windows.
