Author Topic: 1 inch pex 3 way zone valve  (Read 10298 times)
heat550
  • OWF Brand: Heatmor
« on: October 04, 2015, 01:49:20 AM »
Hi all
  Do they make 3 way zone valve with pex ends or theaded
So you can screw pex connectors in to them. Instead of sweeting
Let me know as this might be wish full thinking. 19 years ago I ended up replacing 2 because of leaks it was costly mistake.
At this point I know hotter torch would of done the trick. But theads or pex end would be easyer to deal with. Thanks for any info.
Heat550
BoilerHouse
  • OWF Brand: Home Built
Re: 1 inch pex 3 way zone valve
« Reply #1 on: October 05, 2015, 02:57:14 PM »
Many different sizes, types , and styles from several manufactures
A few;
http://www.supplyhouse.com/Erie-Zone-Valves-15921000
Muskoka, Ont
heat550
« Reply #2 on: October 05, 2015, 06:41:51 PM »
A few;
I found 3/4 3 way with threads but not a 1 inch .
Heat550
BoilerHouse
Muskoka, Ont
heat550
« Reply #4 on: October 05, 2015, 07:38:55 PM »
A couple here;
http://www.supplyhouse.com/Erie-VT3427G14B020-1-NPT-3-Way-PopTop-Series-Valve-8-CV
http://www.supplyhouse.com/Erie-VT3427G13A020-24V-1-NPT-3-Way-Zone-Valve-15-PSI-7-5Cv
That's great. I searched everywhere and could not find them .
What I want to do it screw 1 inch pex ends in and use pex from there I have crimp tool and stuff . you just made my job easyer.
 need to get them on order.  I have 24 v Honeywell's . would the 120v use same kinda thermostats or is it a different setup. Thanks alot for the find.  It's so awesome.
Heat550
BoilerHouse
« Reply #5 on: October 05, 2015, 08:41:05 PM »
No expert but think you would have to stick with your existing voltage.
Another one, pricier though.
http://www.supplyhouse.com/Taco-V100T3G1ZA024Q4A1-1-3-Way-Geo-Sentry-GeoThermal-Zone-Valve-Threaded-Normally-Closed
Muskoka, Ont
« Reply #6 on: October 05, 2015, 09:13:02 PM »
You will want to watch the CV numbers and look for one with the highest you can find. The last link shows the rating is 3.0 which may cause significant flow issues.
heat550
« Reply #7 on: October 05, 2015, 09:36:12 PM »
Does anyone else use these Schneider zone valves are they as good as Honeywell ones I have. Never had any issues with Honeywell ones. For 19 years knock on wood.  Wonder how small hole is in the 1  I'm sure about 1/2inch ..
Heat550
« Reply #8 on: October 05, 2015, 10:13:10 PM »
The cv number will give you an idea of the size of the hole. The CV rating is the number of gallon per minute to drop pressure 1psi. (1 psi = about 2.3' of head)
heat550
« Reply #9 on: October 05, 2015, 10:55:39 PM »
So best I can do is the 1 inch npt Cv of8.
Heat550
« Last Edit: October 05, 2015, 10:58:03 PM by heat550 »
