Author Topic: Flushing plate exchanger  (Read 16618 times)
ambonci
  • OWF Brand: SHAVER 165
« on: October 04, 2015, 05:17:57 AM »
Getting ready to fire up the boiler within the next few weeks and I wanted to flush my plate exchanger.  Can I use a pressure washer?  Compressed air?  Water hose?  and do I need chemicals and f so what should I use?
Thanks
Adam
Re: Flushing plate exchanger
« Reply #1 on: October 04, 2015, 09:26:13 AM »
Get yourself a five gallon bucket, a puddle pump and several gallons of white vinegar.
Dump the vinegar in the bucket, attach a garden hose to the puddle pump and the other end to your access valve at the plate exchanger, run another hose back to the bucket, plug in the puddle pump and allow to run for several hours. Washing machine hoses work pretty well for this.
fireboss
« Reply #2 on: October 04, 2015, 03:40:21 PM »
I just swap my plate exchanger and it looked brand new like the day I put it in 5 or 6 years ago!
yotehunter66
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« Reply #3 on: October 04, 2015, 05:16:16 PM »
I used a garden hose and back flushed through my return line.
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
Troybilt 27 ton log splitter
« Reply #4 on: October 05, 2015, 04:53:27 AM »
All my manifolds have added drain valves with ball valves to isolate the heat exchanger for flushing, I use commercial coil cleaner and a liberty pump, five minutes on each side, flush them with clean water and they are as good as new!
WoodMOJoe
« Reply #5 on: October 05, 2015, 07:37:24 AM »
Slim (or anyone else), do you have a pic of this setup that you could post sometime?  And what is a liberty pump?  Thanks.
sceptre74
  • OWF Model: BL 28-40
« Reply #6 on: October 05, 2015, 03:59:10 PM »
Here's a pic of one of slim's setups
« Last Edit: October 05, 2015, 04:01:25 PM by sceptre74 »
ambonci
« Reply #7 on: October 05, 2015, 04:28:23 PM »
What is the name of the cleaner? I don't have drain valves on them so id have to remove lines then flush.
« Reply #8 on: October 06, 2015, 04:37:32 AM »
Thanks Sceptre, the wife filed a bunch of my old pictures and I can't figure out how to get them back, the liberty pump is simply a good quality pressure pump that most service guys carry with us for evacuation of tanks like hot water or in an emergency for transferring most any liquid, there are lots of commercial coil cleaners at the plumbing supply houses.
WoodMOJoe
« Reply #9 on: October 06, 2015, 05:17:13 AM »
Thanks Sceptre and Slim, I think I get it now.  Think I will use the ball valves with the hose drain built in...and get to shopping for a little transfer pump.  Probably still about 4-6 weeks from fireup here in the Ozarks.
oaky
  • OWF Model: BL-2840
« Reply #10 on: October 06, 2015, 07:08:06 AM »
Webstone makes ball valves with purge/drain valves: http://www.ebay.com/itm/231090208836?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I have them throughout my system including a model with built in unions which I find are great.
Husqvarna 272
Husqvarna 55
27 Ton Cub Cadet Log Splitter
WoodMOJoe
« Reply #11 on: October 07, 2015, 06:51:28 AM »
Oh yeh, the ones with unions are just what I need, got 4 on the way, thanks oaky.   :thumbup:
oaky
« Reply #12 on: October 07, 2015, 07:16:57 AM »
You're welcome, WoodMOJoe.
Husqvarna 272
Husqvarna 55
WoodMOJoe
« Reply #13 on: October 07, 2015, 03:45:32 PM »
WoodMOJoe
« Reply #14 on: October 07, 2015, 03:47:48 PM »
When you guys say "coil cleaner"...do you mean the stuff that is typical used externally on evap/condenser coils?
And if so, do you circulate it full-strength through the pump or diluted?
