Author Topic: question on hanging heat exchanger in barn  (Read 5457 times)
pointer80
  • OWF Brand: woodmaster
  • OWF Model: 4400 heavy duty
« on: October 07, 2015, 04:54:14 PM »
hello all,  I have a 100,000 btu hanging heat exchanger in my workshop and I have a question about the feed and return lines.  Does it matter how I hook up the lines to the hanging unit?  What I mean is which line goes on the top or bottom hook ups on the hanging unit?  Thanks all.
Re: question on hanging heat exchanger in barn
« Reply #1 on: October 07, 2015, 06:04:24 PM »
Well on the one hand if the supply is hooked to the bottom, should get all the air out, you’ll get warmer air though if the supply is hooked so it flows thru the part first that the air exits. Or other words you want the hottest water away from the fan.
pointer80
« Reply #2 on: October 08, 2015, 09:53:49 AM »
Hey thank you guy's,  That makes perfect sense.
