Pages: 1 2 [3] 4
Author Topic: Hello  (Read 44101 times)
rosewood
Re: Hello
« Reply #30 on: February 17, 2011, 03:30:10 PM »
nice looking job. :thumbup: you might find the need to keep the exhaust pipe pitched ever so slightly to drain the sooty condensate that will develope from a non insulated exhaust pipe.keep up the good work!
jackel440
Re: Hello
« Reply #31 on: February 17, 2011, 05:14:59 PM »
You are so right on that drip! ;D
My temporarily permanent stack will sure drip real good.Its seams to have quite for the last few weeks,but I think it has just plugged up the seams. ::)
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
Airgap
Re: Hello
« Reply #32 on: March 16, 2011, 09:48:08 AM »
Here it is up and running... Been running for a little over a month...The only real problem I had was I tried to run a 007. Upgraded to a 009 and have had zero problems.
Airgap
Re: Hello
« Reply #33 on: March 16, 2011, 09:50:17 AM »
After I read your post the first time, I went out and checked, and it was dripping otu of the cleanout cap...
rosewood
Re: Hello
« Reply #34 on: March 16, 2011, 06:24:31 PM »
i dont have that problem with my owb,but i put a wood stove in my garage at my house in northern nh and didn't use insulated pipe ..because of the cost, and the pipe out side had 12'' sooty icicle's hanging off. when it was burning! liqufied creasote is pretty corrosive and i would hate to see your stack rot off.happy burning! ;D
Ridgekid
Re: Hello
« Reply #36 on: October 07, 2011, 09:00:51 AM »
Nice pics. Finally a post where I can see the pics. (also checked out your links above) NICE JOB!
Re: Hello
« Reply #37 on: October 07, 2011, 10:25:06 AM »
i have also seen the pics...and agree..good work
jackel440
Re: Hello
« Reply #38 on: October 07, 2011, 07:07:53 PM »
looks great! :thumbup:
Nice install of your inside piping
Do you need to put a mounting bracket on your plate exchanger to support  the wieght?
I like what you've done
New Holland LS170
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
Airgap
Re: Hello
« Reply #39 on: October 08, 2011, 08:03:56 PM »
Thanks all.
No support needed on the plate ex. There's a hanger on the pipe about 18" above it after an ell, and it's cut in right above the water heater.
Airgap
Re: Hello
« Reply #40 on: January 13, 2012, 01:20:15 PM »
Year 2 going great so far....Didn't run it long enough at the end of last winter to know for sure....
This Spring/Summer, I will be adding a domestic recirc line, and piping a HX into the air handler for my upstairs bonus room(800 sq. ft.)...
Rome wasn't built in a day.... ;D
chuck_brown14
  • OWF Brand: Wood Boiler LLC
  • OWF Model: Extreme
  • 419-553-6507
Re: Hello
« Reply #41 on: January 13, 2012, 06:17:57 PM »
nice boiler,
Chuck
bullworker1
  • OWF Brand: mechanicaly fluidized bed, brickless, home made super gasifier
  • OWF Model: 1
Re: Hello
« Reply #42 on: January 13, 2012, 08:08:16 PM »
nice job, where did you get the design ?   i'm a welder /fabricator / millwright also.
Chevy silverado
Ford ranger
NH 3040 with farmi winch
Miller aead200le, miller 251 with spool gun, verson 8 ft 60 ton press brake
Airgap
Re: Hello
« Reply #43 on: January 14, 2012, 01:44:50 PM »
Thanks. I kind of borrowed ideas from several stoves. Then I kind of winged it...
If/when i were to do another one, I would change a lot of things....I won't go into that now, but I learned a lot reading this forum...
Using pipe instead of plate would have saved so much time and work, but live and learn...
bullworker1
  • OWF Model: 1
Re: Hello
« Reply #44 on: January 14, 2012, 03:53:46 PM »
Before you build another we should talk, i'm also thinking of building another with a few changes, but round would not be one of them. If yo're interested i could explain.
Chevy silverado
Ford ranger
Pages: 1 2 [3] 4
