Author Topic: cheapest heat  (Read 13107 times)
ruger
cheapest heat
« on: January 09, 2011, 04:00:12 PM »
What is the cheapest way to heat a  12x16 outbuilding with a owb
R W Ohio
Re: cheapest heat
« Reply #1 on: January 09, 2011, 04:16:17 PM »
Build your own OWB. That is what our son did. And I'm proud to say he did a very good job and it works very well.
R W Ohio
Canal Fulton,Oh.
Re: cheapest heat
« Reply #2 on: January 09, 2011, 04:41:21 PM »
big old rad out of  a truck from the back 50 and an old furnace blower hooked via 110 volt thermostat is about as cheap as i can think of
Re: cheapest heat
« Reply #3 on: January 09, 2011, 06:40:15 PM »
 If you find a big old cast iron radiator you wouldn't even need a fan.
Re: cheapest heat
« Reply #4 on: January 09, 2011, 07:06:20 PM »
would have to be a couple of big old rads and they don't recover very quick if you open a big door and let a bunch of heat out?
Re: cheapest heat
« Reply #5 on: January 09, 2011, 11:25:17 PM »
 Maybe if you have a garage door open for a while you would need a fan to recover. I've been using these huge cast rads in basements some.  I have customers who the two or three rads in the basement keep the whole house warm enough that the duct system never comes on.
juddspaintballs
Re: cheapest heat
« Reply #6 on: January 11, 2011, 03:11:16 PM »
You could use a cast iron radiator or two (if you found them cheap) with no blower.  If you open the door and the shop doesn't recover fast enough, throw a $10 box fan behind one of the radiators and that should warm the place up quickly.
Re: cheapest heat
« Reply #7 on: January 11, 2011, 04:40:30 PM »
you folks in the USA must have an abundance of cheap rads. here in Ontario Canada the scrap price for them is $230 a ton today. that makes "old style cast rads" in these parts ...not cheap
But the cast rads would be very quiet and i know they still use them in paint rooms at auto body shops (no explosions and no dust)
juddspaintballs
Re: cheapest heat
« Reply #8 on: January 11, 2011, 05:35:42 PM »
I found mine in a 1960's mansion that was "donated" to us to breech and break up as training prior to demolition to build 4 mansions on the property.  A little work with a chop saw and lifting into the back of the fire engine, and I had me a free cast iron radiator.
Re: cheapest heat
« Reply #9 on: January 11, 2011, 05:36:59 PM »
 Many rads do go to scrap but I find a lot of people like the idea of them being used for something. I have had guys give them to me instead of making money on scrap just because I was going to use them. I watch craigslist like a hawk and find some about once a year.
Re: cheapest heat
« Reply #10 on: January 11, 2011, 05:38:39 PM »
Hey, are you payed or volunteer? I'm on a volunteer station here in Va. Last year I ran the most calls, around 60%.
juddspaintballs
Re: cheapest heat
« Reply #11 on: January 11, 2011, 06:58:34 PM »
Both.  I'm a career firefighter and I volunteer at my local station on my days off.
jackel440
Re: cheapest heat
« Reply #12 on: January 11, 2011, 07:27:06 PM »
:thumbup:  to you 2 guys for running into places that other people are running out of.Thanks for what you do.
I apologize for the hi-jack of the thread.Carry on...... :D
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
1grnlwn
Re: cheapest heat
« Reply #13 on: January 15, 2011, 04:23:50 PM »
I converted my moms old gas furnace to a water furnace.
« Last Edit: January 15, 2011, 04:29:53 PM by 1grnlwn »
tulenutn2o
  • OWF Brand: HeatSource1
  • OWF Model: Earth Energy 190
Re: cheapest heat
« Reply #14 on: January 15, 2011, 06:04:02 PM »
Nice neat job there. Have you thought about a transition from the blower opening up to coil to lessen the turbulence a bit? Just a thought. Again, nice work. :thumbup:
