Author Topic: cleaning firebox  (Read 8098 times)
hofmus
  • OWF Brand: heatmor
  • OWF Model: 200
cleaning firebox
« on: November 01, 2015, 10:28:45 AM »
Almost time to fire up. Is there a way to get stubborn creosote off sides of firebox inside? I tried scrapping , but still hard as a rock? Any suggestions? Heatmore 200cs Thanks
fireboss
Re: cleaning firebox
« Reply #1 on: November 01, 2015, 12:12:36 PM »
Burn lots of cardboard that will get it off!
U.P. Doug
  • OWF Model: 7500
« Reply #2 on: November 01, 2015, 03:46:03 PM »
I burned cardboard all day in the spring and it worked great. Turned the heat up in the garage to keep the fire going strong.
hofmus
  • OWF Model: 200
« Reply #3 on: November 01, 2015, 07:15:42 PM »
Thanks for the info, Ill try it !
jerkash
  • OWF Brand: Legend
« Reply #4 on: November 02, 2015, 04:38:26 AM »
Grinder or drill with a wire brush on it works after you burn it off with cardboard
pullerbob
  • OWF Brand: Taylor
  • OWF Model: 750
« Reply #5 on: November 02, 2015, 07:01:15 AM »
You can also through some aluminum cans but you need it to be hot enough that it will melt the cans.
