Author Topic: WHEN SHOULD WE BE CONCERNED OF RADIANT FLOOR FREEZING IF HEAT IS OFF  (Read 8988 times)
caper
  • OWF Brand: heatmaster 5000
HELLO GUYS, QUICK QUESTION, I HAVE IN FLOOR RADIANT HEAT IN MY ATTACHED GARAGE, ITS ONLY FOUR YEARS OLD SO ITS WELL INSULATED, NOT TURNING THE HEAT ON OUT THERE FOR ABIT YET, NIGHTS ARE GETTING COLD, WHEN SHOULD I GET CONCERNED ABOUT ANYTHING FREEZING, IM THINKING IT HAS TO BE REALLY COLD BEFORE ANYTHING FREEZES FOR LONG PERIODS OF TIME...ANY SUGGESTIONS
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Cape Breton, Nova Scotia
Canada
Re: WHEN SHOULD WE BE CONCERNED OF RADIANT FLOOR FREEZING IF HEAT IS OFF
« Reply #1 on: November 05, 2015, 06:49:59 PM »
I would keep the pump running and keep an eye on the water temp. Once it gets down to the mid 30's I would turn it on.
schoppy
  • OWF Model: G200
« Reply #2 on: November 05, 2015, 09:17:21 PM »
Exactly right RSI on keeping the pump running. A garage especially will have colder areas near the door depending on how good your thermal break is and perimeters as compared to say the center of the garage. Running the pump is cheap insurance to a burst line near the door.
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
caper
« Reply #3 on: November 06, 2015, 01:59:40 AM »
interesting, what if your system uses only one pump to circulate your hot water to your zones...this year I just wanna see how efficient the boiler is for a month without the heat on in the garage and bonus room above it that's all, come dec, then I wanna turn on those zones...just a lil experiment
« Last Edit: November 06, 2015, 02:01:23 AM by constable72@hotmail.com »
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Canada
cartod
  • OWF Model: 10,000e
« Reply #4 on: November 08, 2015, 04:33:06 PM »
I think you will see a noticeable reduction in wood consumption.   I was thinking about putting a timer on my garage pump and just have it come on for 15-20 minutes every day.
« Reply #5 on: November 08, 2015, 08:37:39 PM »
Might still freeze, can you install a three way zone valve and leave the pump run all the time then use an aqua stat on the radiant loop to open the zone valve if the temp drops much into the 30’s?
cartod
« Reply #6 on: November 08, 2015, 09:18:44 PM »
Thats what I have now and with the bonus room above and cars coming in and out I don't need it.  I don't need a constantly warm garage.   I just want the floor a bit warm at night for the dogs kennels.
« Reply #7 on: November 08, 2015, 10:19:20 PM »
Gotcha, if you already have the freeze protection shouldn’t be hard to add a timer that comes on at a set time.
