Author Topic: Home made shovel and rake?  (Read 8111 times)
Watt2323
  • OWF Model: BL-3444
  • Oxford, Indiana
« on: November 12, 2015, 07:34:52 AM »
I am looking to make or buy a long handled shovel and rake, anyone have any suggestions?
Stihl 661 & MS 291
County Line 35 ton log spliter
P&M BL-3444 OWB
Lots of wood
U.P. Doug
  • OWF Model: 7500
Re: Home made shovel and rake?
« Reply #1 on: November 12, 2015, 04:51:07 PM »
I bought a shovel, rake and hoe at a garage sale with bad handles. I removed the wood handles and used steel tubing instead. Just welded the steel tubing to the steel shovel and other pcs. Made the handles nice and long and burn free. I work in a tubing shop, but 1 inch conduit might do the trick as well.
Watt2323
  • Oxford, Indiana
« Reply #2 on: November 20, 2015, 08:56:51 AM »
ok thanks I appreciate it
Stihl 661 & MS 291
P&M BL-3444 OWB
Lots of wood
« Reply #3 on: November 20, 2015, 01:58:24 PM »
I put 3/4" conduit on a rock rake the same way.  It works well.  1" probably would have worked better.  For the shovel, you might want to use something a bit more sturdy than conduit, however.
« Reply #4 on: November 20, 2015, 05:05:16 PM »
A piece of black pipe in 1/2” would probably be stout enough for the shovel, 3/4” definitely would be
« Reply #5 on: November 20, 2015, 10:03:50 PM »
1/2" black iron would be stout enough, but quite skinny to be holding onto.  3/4" should be about right though.
gspren
  • OWF Model: ML 30
« Reply #6 on: November 22, 2015, 11:08:45 AM »
  A few years ago I got a round point shovel with about 1" dia conduit handle at a auction for 50 cents, not what I'd use for digging dirt but for ashes and an occasional pile of used dog food it's fine.
Portage & Main ML30
Stihl 261
Stihl 044 (15 years old)
Stihl 041 (30 years old)
Yamaha Kodiak 4 Wheeler
John Deere 2355 4x4 loader tractor
70 acres (23 wooded)
Bondo
  • OWF Brand: Home built
  • Master General Re-Engineer
« Reply #7 on: November 28, 2015, 11:54:58 AM »
Ayuh,....    I've got an ole garden hoe head welded to the end of a piece of 1" fence pipe/ rail for workin' the firebox,.....
A square point blacktop shovel, not good enough to shovel blacktop anymore for scoopin' out ashes, 'n arrangin' logs when loadin',....
Just use a plain jane garden rake for cleanin' up bark, 'n crap,.... Handle rots off, toss it, 'n buy another,...
Bought a 10 tine $h!t fork a few years ago, which works great for shovelin' the bark, 'n crap into the boiler,....
The short D handle rotted off in a couple years, so I grafted on a full length blacktop shovel handle onto it,...
Ain't gotta bend over so much with it now,....
Watt2323
  • Oxford, Indiana
« Reply #8 on: January 14, 2016, 10:08:35 AM »
Thanks for he heads up these are all helpful! Sorry for the delay in my response.
Stihl 661 & MS 291
P&M BL-3444 OWB
Lots of wood
