Author Topic: leaking out the overflow  (Read 11426 times)
cjf12
  • OWF Brand: mahoning
  • OWF Model: 200
« on: November 30, 2015, 08:38:11 AM »
My overflow is continuously running.  Where could all the extra water be coming from.  I have a water line plumbed to feed it when it gets low with a ball valve and just checked the ball valve and it is still good.  The only other place I can think of is the plate exchanger.  Is it possible my potable water is blowing through a hole and filling up the boiler?  My hot water at the spigot is still clear with no sign of it mixed with nasty furnace water.  Any other place I may be missing or do you all think this is where it's at.  System is about 10 years old.
Re: leaking out the overflow
« Reply #1 on: November 30, 2015, 08:51:41 AM »
I would be checking it ASAP
cjf12
  • OWF Model: 200
« Reply #2 on: November 30, 2015, 09:05:29 AM »
How would you figure out that's where the leak is?
« Reply #3 on: November 30, 2015, 09:09:12 AM »
how about turning the water off on the pressurized side and seeing if the issue continues, I have never seen them leak but i'm sure it can happen.
AirForcePOL
  • OWF Model: G400
« Reply #4 on: November 30, 2015, 10:07:10 AM »
Are you on a well by chance?  If it is a significant amount of water, you could try not running any faucets and monitoring the pressure on the well tank.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
fireboss
  • OWF Brand: central boiler
  • OWF Model: 6048
« Reply #5 on: November 30, 2015, 03:35:38 PM »
How about expansion? What is your temp and when did you fill it last?
cjf12
  • OWF Model: 200
« Reply #6 on: November 30, 2015, 04:46:17 PM »
No well, just spring fed and has a manual fill with a ball valve.  I shut off the ball valve that feeds for domestic meaning all valves are shut that are plumbed to the furnace.  Came back after hunting for about 4 hours and it still is trickling out.   I'm baffled.  If it's not getting water it would dry up soon but how is it coming from the overflow????
shepherd boy
  • OWF Model: C375
« Reply #7 on: November 30, 2015, 05:38:29 PM »
I have seen several plate heat exchangers leak through. I would first check the stove fill ball valve, if it is not that it got to be the exchanger.
Let the youngin's have it
 Gettin' old and lazy
Steinacher Sales
« Reply #8 on: November 30, 2015, 06:16:09 PM »
Ball valves do leak sometimes could be a faulty valve.
Greg Steinacher
618-401-0726
« Reply #9 on: November 30, 2015, 06:53:22 PM »
How did you check the ball valve?
If your absolutely sure it’s not the ball valve then turn the domestic side off to the FPHE and see if it continues to overflow, or if possible shut your stove down and disconnect the stove side of the FPHE and see if water continues to come out from the domestic side.
