Author Topic: i need to run another loop. Question on draining  (Read 5861 times)
adamant
    • my pic site
« on: December 04, 2015, 08:48:34 PM »
I need to add another loop to my Central Boiler 6048. I need to drain some water .. I never did this. Some say to just undo the plug and hurry to thread a valve on and some say to completely drain the unit..
What's the proper way?  U hate to drain and waste the treated water. .
gas forced hot air/gas hot water
buck supreme insert 2/14/1991 to 2/21 2007 (rip)
LOPI freedom bay insert. (present)
central boiler classic 6048
NEW JERSEY
what we do on the weekends
http://community.webshots.com/user/adamant117
http://adamant.pictiger.com/
Re: i need to run another loop. Question on draining
« Reply #1 on: December 05, 2015, 04:38:41 AM »
It's going to be hot and fast, safety says drain it first but a trick we use on oil tanks is to put a vacuum on the vent to slow the escaping water.
« Reply #2 on: December 05, 2015, 07:40:47 AM »
Yep, I’ve done the same on engines, put a vacuum on the radiator and if your quick and good (like me  :D) you can get the block heater changed out and lose little to no coolant.
