Author Topic: 110 thermostat questions  (Read 12101 times)
Watt2323
  • OWF Model: BL-3444
  • Oxford, Indiana
« on: December 17, 2015, 06:54:26 AM »
ok I am as sharp as a balloon but should I have as much trouble as i am finding a 110 thermostat? I have looked at menards home depot and lowes with no luck. Anyone have suggestions where to purchase them quick? I am needing it to finish the install
thanks
Stihl 661 & MS 291
County Line 35 ton log spliter
P&M BL-3444 OWB
Lots of wood
Re: 110 thermostat questions
« Reply #1 on: December 17, 2015, 07:09:37 AM »
You should be able to find it on the shelf of any decent hardware store, it will be called a line voltage thermostat.
« Reply #2 on: December 17, 2015, 07:14:15 AM »
Line voltage thermostat, Supplyhouse or WWGrainger also have a large selection if your local hardware or home improvement store doesn’t have one you like.
tinfoilhat2020
  • OWF Brand: POS
« Reply #3 on: December 17, 2015, 07:23:34 AM »
menards, home depot and lowes all carry them...honeywell line thermostat
Watt2323
  • Oxford, Indiana
« Reply #4 on: December 17, 2015, 07:29:22 AM »
ok then, this https://www.menards.com/main/heating-cooling/electric-heat/thermostats-freeze-alarms/honeywell-low-temperature-thermostat/p-1444433407212-c-12864.htm?tid=-131252016135034791 should work if so I was looking in the wrong area of the store they arent with the regular area of the store
Stihl 661 & MS 291
P&M BL-3444 OWB
Lots of wood
AirForcePOL
  • OWF Model: G400
« Reply #5 on: December 17, 2015, 08:30:44 AM »
Watt, the link you just provided is a 24V thermostat. Are you just looking for something for a garage?  If so, the one in this link will work fine.  The only downside is that it has a 3 deg. differential.  https://www.menards.com/main/heating-cooling/electric-heat/thermostats-freeze-alarms/cadet-by-honeywell-22-amp-single-pole-wall-mount-thermostat/p-1444426129990-c-12864.htm?tid=7737635989364346050
Be careful if you buy a digital line voltage t-stat as some of them are for only for use with baseboard heat and they will fluctuate the voltage when the t-stat turns on, so it won't work well with a blower motor.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
Watt2323
  • Oxford, Indiana
« Reply #6 on: December 17, 2015, 09:32:54 AM »
wow didnt think about that I went to Honeywell and one like this hopefully this will get the install done
Stihl 661 & MS 291
P&M BL-3444 OWB
Lots of wood
AirForcePOL
  • OWF Model: G400
« Reply #7 on: December 17, 2015, 09:37:38 AM »
That one looks like a standard line voltage thermostat.  It should do the job fine as long as it is 120V and can handle the amperage of your blower.
Athens, Illinois
Stihl MS 290
Watt2323
  • Oxford, Indiana
« Reply #8 on: December 17, 2015, 10:38:56 AM »
I talked to a guy I work with who is an electrician and he thinks it should be fine but if my house burns down he said not to call him so that was reassuring ha
Stihl 661 & MS 291
P&M BL-3444 OWB
Lots of wood
« Reply #9 on: December 17, 2015, 07:36:08 PM »
Menards has lux100 thermostats. They just have a plug on the front.
farmboythegreat
  • OWF Brand: freisen
  • OWF Model: 33hd
« Reply #10 on: December 23, 2015, 05:58:09 AM »
can a guy hook ... lets say a squirrel cage  fan to these thermostats ?
Muir Ontario Canada
AirForcePOL
  • OWF Model: G400
« Reply #11 on: December 23, 2015, 06:16:07 AM »
Sure can.  You can wire up a series of switches to allow the use of all the speeds also.
Athens, Illinois
Stihl MS 290
