Author Topic: Has anyone heard of Acme furnace company in Mo?  (Read 19520 times)
countryguy
« on: January 27, 2011, 12:26:46 PM »
 If you have heard of them or own one give me the good,bad or whatever you have heard about them. I cannot find any info other than their website.
juddspaintballs
Re: Has anyone heard of Acme furnace company in Mo?
« Reply #1 on: January 27, 2011, 03:33:57 PM »
I think Wile E. Coyote had one.
jackel440
« Reply #2 on: January 27, 2011, 03:56:39 PM »
;D that's funny right there.
On a serious note I have not ever heard of them.
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
« Reply #3 on: January 27, 2011, 06:53:14 PM »
I've heard they use the same gas line pipe as Shaver but I don't know if its true or not.  Other than that I have not heard anything.
« Reply #4 on: January 27, 2011, 10:21:07 PM »
I just looked at their website and am trying to figure out what this is supposed to prove, they have it in several places.
Quote
Greater Water Capacity
Acme Furnaces have a 235 gallon capacity giving you more BTUs for your money.
A BTU is the amount of heat it takes to raise the temperature of a pound of water by one degree.
If you start with 55 degree water and you raise it to 180 degrees this is a 125 degree change.
Water weight 8 lbs. per gallon.
235 gal. x 8 lbs. = 1880 lbs.
1880 lbs. x 125 degrees = 235,000 BTUs
Don't be fooled, this is a proven fact you would have to heat 100 gallons of water to 435 degrees to extract 300,000 BTUs. That's not possible or even smart to try!
jackel440
« Reply #5 on: January 28, 2011, 12:43:26 PM »
Ummmm.....OK.... scratching head as I walk away....LOL ;D
New Holland LS170
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
thutch15
  • Newbie
« Reply #6 on: August 29, 2011, 12:04:53 PM »
Is the good or bad?
« Reply #7 on: August 29, 2011, 07:07:07 PM »
Is the good or bad?
thats horrible...   something as important and important should be handled with new, tested, quality material to avoid future problems.  just scroll down to the the shaver section of this site and you'll see one customer who's on his second shaver in like 2 years and its already leaking as well.  he said that the water jacket is so thin and rusted he can poke his finger through it.
thutch15
  • Newbie
« Reply #8 on: August 29, 2011, 09:37:53 PM »
Is the good or bad?
I have seen multiple youtube video's of multiple brands that have leaking problems.  It is making me think twice about getting one period.  When I checked out the Acme Furnance it says it has 5 year 100% warranty on leaking and 20 year prorated warranty on leaking.
« Reply #9 on: August 29, 2011, 09:45:07 PM »
A lot of companies sell hundreds a year with no leaks, proper stove maintenance is important, but for them to have leaks due to bad metal is different.
You want quality, pay for it.  Stick with your bigger brands such as central boiler, heatmaster, woodmaster, natures comfort.  No leaking problems there with mentioning
Avoid the cheap copies and sloppy craftsmanship, if there using scrap metal to build stoves that says enough.  I'd avoid stuff like acme, taylor, and shaver and go with a top brand
BIGDIESEL20S
  • OWF Model: H-2
« Reply #10 on: August 30, 2011, 06:57:33 AM »
Yes I have heard of them. Thats what we had in our basment at home when I was a kid. Its been there for almost 30 years and still works. But its a indoor forced air furnace.
2002 F250 SUPER DUTY 4X4
1994 CHEVROLET S-10 4X4
HOME MADE 20 TON SPLITER
STIHL: 009, 011, MS250, 026, MS260, 028 SUPER,  028FARMBOSS, 029 SUPER, 031, 031 SUPER, 066.
176 ACERS HALF WOODS
HOME MADE PICKUP BED TRAILER
801 FORD POWERMASTER
B414 ITERNATIONAL
H FARMALL
