Author Topic: 400dcss throwing sparks  (Read 10284 times)
heat550
  • OWF Brand: Heatmor
« on: January 18, 2016, 01:10:14 AM »
Has anyone else noticed this ? 400dcss is a spark launcher from chimney between cycles . I have sparks shooting out about 10 feet . every once in while .this is after all moisture out of wood . I'm burning about 25% moisture oak right now .  this all started after putting in all dry oak . wonder if its crackle wood :)  I looked there little pieces of black carbon looking pieces . Im guessing I'm just burning  build up off in flu and chimney as its -17f right now . Might need some kind of cap or something slow down the launching .
old 200css had one of the stainless steel caps . If i wasn't in middle of bunch of oak trees I wouldn't care but leaves do burn :)
Heat550
tinfoilhat2020
  • OWF Brand: POS
Re: 400dcss throwing sparks
« Reply #1 on: January 18, 2016, 04:50:40 AM »
When I'm burning oak under %20 I get sparks after the first fresh load....it crackles alot, u can here it outside the stove! Had some white oak at 18% earlier this year and it was shooting out sparks after first load. I have a SS chimney cap but only use it in the fall and early spring when it is wet/rainy. I have found to get a much better draft without it on...I check chimney this weekend to see build up. Haven't check it since October 1st....there was nothing :) completely empty
heat550
« Reply #2 on: January 20, 2016, 12:18:42 AM »
I will have to get a cap atleast to slow it down. Do you have picture or style of your cap.
I could put on when needed. Because them sparkes really rocket out of there white to red hot.
Thanks for your post.
Heat550
tinfoilhat2020
  • OWF Brand: POS
« Reply #3 on: January 20, 2016, 04:07:11 AM »
heat550
« Reply #4 on: January 23, 2016, 10:55:20 PM »
heat,
this is the one i bought...works great...easy to take on and off. Just turn and lock.
https://www.menards.com/main/heating-cooling/venting/insulated-double-wall-stove-venting/supervent-8-s-s-deluxe-rain-cap/p-1444453720087-c-6894.htm?tid=-7128955040724301786
Mines shooting so many sparks Im going to go pick this one up tomorrow.I seen they had one but didn't know if it was the right one. Now I know it is . here seems like draft isn't a issue. It might slow down crazy sparks.
Heat550
heat550
« Reply #5 on: January 24, 2016, 03:01:22 AM »
heat,
Thanks for the info . when I seen it at Menards I was like is that the right one naaaa I have to makesure I have right style lock . I looked at box my extention came in when i got home and it was dam I need to make another trip to menards :) your post sealed the deal :)  Ya for some reason if i have bed of coals covering whole grate I get these dam sparks coming out . never seen that problem before . wet wood , dry wood it does not matter .  Might be i have just enough heat load stove burns hotter I don't know .
hopefully cap will  atleast stop them from the 20 ft air born white hot spark launch . Have to keep this dragon fallout contained  :thumbup:
Heat550
lindnova
  • OWF Model: 200 CSS
« Reply #6 on: January 25, 2016, 06:50:42 AM »
I have the basic cap with some expanded metal around.  Slows down the fast fliers, but doesn't block all the sparks.  I get some if I rake and reload during or just after the fan was on.  Also makes a big difference in wood types for me.  I had some aspen and possibly mulberry in last fall and boy did it spark a lot.  I was concerned about catching the field stubble on fire.
Normally sparks are not an issue for me.
Stihl ms260, ms362, msS461
Huskee 22 TN Splitter
Kubota BX2200 w/ Loader
tinfoilhat2020
  • OWF Brand: POS
« Reply #7 on: January 25, 2016, 07:41:42 AM »
If I load my 400 away from the door a bit and load the back of the firebox up more instead... I don't get any sparks...even loaded up in front of the door I haven't noticed much. I took my rain cap off as I found it drafts better...but I will put it back o n in the early spring
heat550
« Reply #8 on: January 26, 2016, 02:47:50 AM »
See my old 200css wasn't as bad with crazy sparks . I had a cap on it also just mainly when I fixed it and stirred coals is only noticeable sparks . It seems the 400dcss is fast fliers mega producer  :o But It could be just my wood also as some of its wet Im mixing it with my dry .
Heat550
