Author Topic: Reusing boiler water  (Read 6717 times)
robertj1
  • OWF Brand: natures comfort
  • OWF Model: ncb 325
« on: January 30, 2016, 10:13:55 AM »
 Was thinking about draining boiler this summer. No problems. Just to check if there is any sludge bottom. Maybe pressure washer the insides of water jacket out. It has been 4 years running. Question is, has anybody reused water. Pumped it through a real fine filter while draining and filling. Have always kept boiler treatment up to 1000. Used soft water when I filled it. Water looks crystal clear.
« Last Edit: January 30, 2016, 12:10:14 PM by Sloppy_Snood »
intensedrive
Re: Reusing boiler water
« Reply #1 on: January 30, 2016, 10:18:25 PM »
How many gallons is your boiler?  I just don't see all the hassle.  If you have a open system, treatment will not be over $150 dollars.  Dump it.. add new water.
« Reply #2 on: January 30, 2016, 11:01:30 PM »
I’ve wondered about that, wonder how good boiler water is for the environment if its treated properly?
I’m not a huge green weenie or anything but we do have a state park right across the road and they regularly take water samples.
« Last Edit: January 30, 2016, 11:13:33 PM by mlappin »
« Reply #3 on: January 30, 2016, 11:02:09 PM »
His boiler holds 325 gallons and would require 7 quarts of treatment if refilling using the factory treatment. (should get it to around 1500 ppm)
It would be around $140 to replace it.
If at least some of the treatment is 4 years old, I would just dump it and replace with new stuff. Some people recommend replacing it after 5 years.
robertj1
« Reply #4 on: January 31, 2016, 10:25:03 AM »
Does the boiler treatment degrade over time. Was concerned about dumping on the ground.
yotehunter66
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« Reply #5 on: January 31, 2016, 10:40:30 AM »
Glad mine only holds about 150 gallons or so. I dump mine every year but it only requires a 1/2 gallon of treatmen at about $20. Makes me feel better anyway.
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
Troybilt 27 ton log splitter
