Author Topic: OWB for domestic hot water question  (Read 8819 times)
glock_556
  • OWF Brand: Earth
  • OWF Model: Woodsman 405
« on: February 12, 2016, 02:17:10 PM »
I use my OWB to heat my home and my domestic hot water.  My water temp on OWB is set at 165.  I have noticed that my dish washer has started leaking around the door seal, could this be from the water being too hot?
SE Missouri
Stihl MS362CM
Brave 22 Ton splitter
Re: OWB for domestic hot water question
« Reply #1 on: February 12, 2016, 02:34:34 PM »
I wouldn’t bet on it, I’ve had mine hooked to the DHW for 15 years, never had a leak that wasn’t just a common wear item.
I asked a repairman from Sears about too hot of water, he said almost all the newer high efficiency dish washers have a build in heater to raise the water temp so the “environmentally”  friendly detergent works better.
Only thing I did do for the washing machines (one for work clothes, one for good clothes) was to get the stainless steel braided hoses for the hot side.
« Last Edit: February 12, 2016, 02:36:46 PM by mlappin »
glock_556
  • OWF Brand: Earth
« Reply #2 on: February 12, 2016, 02:41:46 PM »
I know this has probably been discussed a couple million times, but is my water temp set point too low?  It's at 165* with 5* "play"  I've tried it a t 180* and it seemed like the stove worked too hard at that temp.
Any pointers?
SE Missouri
Stihl MS362CM
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
« Reply #3 on: February 12, 2016, 03:25:39 PM »
Where do you live Glock?
Put it into your signature, that way the experts have some idea of your climate and may help with temps on the stove.
Mines,, fan on at 160,, and off at 170.
This works well for me
Very Cold here, all winter.
kk
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
fireboss
« Reply #4 on: February 12, 2016, 04:26:23 PM »
I  run mine @ 185 \195  I have hot water   base board  need to run that Hi to keep the house at 72 ,74. The spoiled  people we are lol. And it keep  the oxygen out of the water!
glock_556
  • OWF Brand: Earth
« Reply #5 on: February 12, 2016, 08:59:17 PM »
Sorry, I'm in SE Missouri about 100 miles south of St Louis
SE Missouri
Stihl MS362CM
agriffinjd
  • OWF Model: BL 3444
« Reply #6 on: February 13, 2016, 06:31:59 AM »
It's not your water that's causing a leak.  I keep my stove at 190 degrees with a 10 degree diff.  I live in snow and cold country and it works great at that temp.  I'd try yours at 180 at least for the set point.
U.P. of Michigan
kommandokenny
  • OWF Model: 4400
« Reply #7 on: February 13, 2016, 07:47:21 AM »
Put that in your signature, or avatar area,for future posting.
http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=7501.0
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
Smokeless
  • OWF Brand: HeatMaster ss.
  • OWF Model: G-100, 200,400
    • PCWoodBoilerSystems
« Reply #8 on: February 15, 2016, 11:23:45 AM »
Hi guys
      Don't forget to use a tempering valve. 140 -150'F is hot enough. You might be used to regulating 180deg water manually at the faucet. But if company comes over it could turn real bad in a hurry. They are easy to install and are cheap.
      Best regards.
Signature:
JDfarmer
  • OWF Brand: NCB 250 coal
  • OWF Model: NCB 250 Coal
« Reply #9 on: February 15, 2016, 01:36:13 PM »
I totally agree. I got one, I can post the brand name if someone needs it. It was $120 I think. Works great; makes the water 140F and it auto adjusts. I had a buddy who's water was 180 and he bumped the shower's cold water switch off, and he got pretty burnt in a few seconds. I think shark bite makes one too for 120F or 160F. Mine you can actually adjust 120-145.
Hi guys
      Best regards.
« Reply #10 on: February 15, 2016, 01:54:10 PM »
Honeywell has a different one out that is inline instead of a T style, much easier to plump in.
http://www.supplyhouse.com/Honeywell-Sparco-AMX100-UPEX-1LF-1-2-Union-PEX-Lead-Free-AMX-Mixing-Valve-90-130F
