Author Topic: BL 2840  (Read 16068 times)
ijon
  • OWF Brand: Portage and main
  • OWF Model: 28-40
BL 2840
« on: February 14, 2016, 04:01:13 AM »
What is the first thing to look for when a BL 2840 won't have the fan come on to start a burn? I have power and it comes on and goes through its cycle, but fan won't come on. >:D
installed in 2014
Crow
  • OWF Model: BL 28-40
  • Eastern Ontario
Re: BL 2840
« Reply #1 on: February 14, 2016, 06:47:06 AM »
 Hey ijon, When you say you have power and its going through its cycle I am assuming you mean the Johnson control is working but just the fan is inoperative correct?
 If that's the case I would shut of the power to the furnace, remove the junction box cover and verify your connections are tight.
 If they are ok, I would remove the fan wires from the box and jump the fan directly with an extension cord as it is a 115 volt motor - if it still doesn't work its dead.
 That would be my suggestion. In the mean time you could open the ash pan door every once in a while to get the stove up to temp.
 Good luck and keep warm.
« Last Edit: February 14, 2016, 07:12:12 AM by Crow »
Re: BL 2840
« Reply #2 on: February 14, 2016, 07:00:01 AM »
I pulled up the wiring diagram on a BL series. if your damper is opening, and you have all good connections to the fan a very real possibility is the fan motor is bad. It can’t be the high temp cutout if the damper still opens.
Crow
  • Eastern Ontario
Re: BL 2840
« Reply #3 on: February 14, 2016, 07:14:33 AM »
On mine the damper door is a flap after the fan that is only forced open by the air from the fan, and weighted to close after fan shuts off.
Strawbale Builder
  • OWF Brand: portage & main
  • OWF Model: ultimizer
    • strawbalefarms.com
Re: BL 2840
« Reply #4 on: February 14, 2016, 11:04:24 AM »
Crow is correct. P&M uses a gravity damper. When the blower kicks on it blows the damper open and when the blower kicks off the damper simply falls shut, no springs or solenoids involved. Check the connections in the junction box, there is a wiring diagram in the manual. If that is not it jump the blower with an extension cord like Crow said, if it still will not start you need to replace it.
Portage & Main dealer Northern Wisconsin, Eastern Minnesota, Upper Peninsula Michigan
rickldb22
  • OWF Model: BL 2840
Re: BL 2840
« Reply #5 on: February 16, 2016, 07:17:22 AM »
If your fan is no good, an option until you get a replacement, is to run a shop vac in "blow". The vacuum can act as the fan.
Rick
Uponthehill
  • OWF Model: 250 & 461 Stihl
Re: BL 2840
« Reply #6 on: February 16, 2016, 02:43:29 PM »
I used this site to do a lot of research prior to and after my purchase. Took some of the veteran advice and now have extra fan & pumps "on the shelf". The way I have it figured is that as long as I have them in stock, they will never fail. My fan is wired with a plug on the cord to shorten my replacement time.  Stay warm...
gainerspot
  • OWF Brand: P&M
  • OWF Model: Ultimizer BL 2840 (soon)
Re: BL 2840
« Reply #7 on: March 02, 2016, 07:37:23 PM »
I have an extra pump but no fan.  Where did you buy it from? I don't have a dealer anywhere close to me.
coolidge
Re: BL 2840
« Reply #8 on: March 03, 2016, 02:03:39 AM »
I wonder if they are the same fan as the Optimizer, I can't get on the P and M website right now.
Western Maine
Re: BL 2840
« Reply #9 on: March 03, 2016, 02:04:14 AM »
If you call their office, they can give you the closest dealer or ship one direct.
gainerspot
  • OWF Brand: P&M
Re: BL 2840
« Reply #10 on: March 03, 2016, 11:41:19 AM »
Thanks slim, I need to call them and let them know about the flapper issue also.
patvetzal
  • OWF Model: ML36
Re: BL 2840
« Reply #11 on: March 06, 2016, 07:56:20 PM »
I also thought my fan was shot then found out about the short cycle setting which was keeping it from coming on. When you switch off, the A419 stops it from restarting until the set point times out. That set point might have been bumped up to 15-20 minutes....Reset it to five or so
Don't be afraid to call the factory with questions as well...
80 acres of Bancroft bush and Ontario rock, a sweet wife, a few chickens, fishing rod, most everything I need....Most of it made by John Deere, Polaris, Stihl, Ruger, Jeep or me...
