Author Topic: Could lose power can you help with this question PLEASE  (Read 12352 times)
Watt2323
  • OWF Model: BL-3444
  • Oxford, Indiana
« on: February 24, 2016, 07:37:44 AM »
ok we are starting to get some bad weather that could bring down power lines. I dont have a backup generator. I am afraid if we do lose power my boiler will overheat. Am i correct in thinking this? If so how can i prevent this?
Thanks in advance
Stihl 661 & MS 291
County Line 35 ton log spliter
P&M BL-3444 OWB
Lots of wood
Re: Could lose power can you help with this question PLEASE
« Reply #1 on: February 24, 2016, 08:23:36 AM »
Let her be, perhaps drop your aqua stat set point by 10 degrees or so before the expected outage, sit back and enjoy! You might look at getting a small inverter so you could run your heat on a 12 volt battery for emergency use.
« Reply #2 on: February 24, 2016, 08:38:07 AM »
Long as all your door seals are good shouldn’t be a problem with overheating. May not want to fill it up either, if somebody is around today just add wood as needed.
We missed the freezing rain crap here and it just went to straight snow. Expected wind gusts of 40 mph with somewhat heavy wet snow is gonna create some misery for somebody, I’ve already went out and started my 9000 watt portable. Started right up, Marine grade Extend is a wonderful thing. Grabbed the skid steer and moved it into the shop so it stays warm just in case.
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
« Reply #3 on: February 24, 2016, 02:26:54 PM »
What about freeze up on the lines[any exposed]
I have backup genny to run pump and Wheel of Fortune in case of blackout!!
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
agriffinjd
  • OWF Model: BL 3444
« Reply #4 on: February 24, 2016, 04:00:05 PM »
I would imagine if the temps aren't too far below freezing then the lines shouldn't freeze, assuming the only exposed ones are right under the stove.  Heat should travel from the stove at least partway into the lines just through natural heat flow.
I've got a standby Generac that comes on automatically when we lose power. Love it!  Have used it twice now; once for 2 hours, second time for an hour.  Runs the whole house and everything.
U.P. of Michigan
kommandokenny
  • OWF Model: 4400
« Reply #5 on: February 24, 2016, 04:08:17 PM »
Got that Generac system also.
I put drain valves in the basement in case of pump failure.[only downside to the whole operation, in my view.]
-45 will freeze the upper part of the lines here for sure.
Just hope someones home if pump fails.@ -45
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
braveblaster
  • OWF Model: 7500
« Reply #6 on: February 24, 2016, 06:56:39 PM »
Thanks in advance
Not familiar with your OWB model but mine (ridgewood) as long as the flap door is closed shut (no air in) there is no fire in the firebox thus no overheating. I just went through it myself with ice storm a few weeks back and power out for just about 4 hours, no problems.
« Reply #7 on: February 24, 2016, 08:57:22 PM »
Want one bad.
Would need a minimum of 24K one to handle all the single phase on the farm. 27K or 30K or would be better.
Have Nat Gas here, so most would say go with that.
However the small amount of prepper DNA I have says what happens if the crap really hits the fan and Nat gas supply gets flaky….
I usually have at least a few thousand gallons of diesel on the farm at all times….
« Reply #8 on: February 24, 2016, 09:39:26 PM »
just installed a generator this year, have not used it yet. 16 KW, enough to power the whole place here
guess I am waiting for the storm of the century to try it out   NOT
kommandokenny
  • OWF Model: 4400
« Reply #9 on: February 25, 2016, 06:28:43 AM »
These things are fantastic.
I got 14kw Generac.
 It comes on as soon as power goes out,and off when power comes back.
Had it 3 years and it gets used 3-5 times a year, where we are.
Runs off propane .
Don't know about nat gas but most oil based fuel is only good for a few months.
Propane is our backup for wood so it was here and an easy hookup.
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
« Reply #10 on: February 25, 2016, 08:45:22 AM »
Diesel keeps for practically ever as long as you keep it treated to keep the algae out.
We fill both combines when done to help prevent condensation in the fuel tanks, both run just fine the next fall.
Never used to be a problem with regular diesel, but the new low sulfur and ultra low sulfur fuels are horrible for getting algae in it, especially since we run 5% bean oil to replace the lubricity lost from the lack of sulfur.
Sulfa used to be used as an antibiotic.
kommandokenny
  • OWF Model: 4400
« Reply #11 on: February 25, 2016, 10:00:54 AM »
The new fuels are  prone to getting gummy.
Didn't know about algie
I use a good stabilizer for all the small engines, all the time,not just for storage
K100- Seafoam work, but I'm not using any gas, no matter what ya put in it,, after a year
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
« Reply #12 on: February 25, 2016, 10:32:57 AM »
Like I said, never had a problem with old diesel long as it’s algae free.
I rarely buy more than a few gallons of gas anymore, when I do it’s at least 89 octane for the small engines and it gets treated immediately with Stabil Marine.
kommandokenny
  • OWF Model: 4400
« Reply #13 on: February 25, 2016, 12:34:29 PM »
10-4 Martin.
Same here,, but 91 octane supposed to have no either.
Run 91  in my old British bike,the e- 10 gas is murder on the carb o rings and any other rubber.
Got off topic,,again,, but this forum is very forgiving.
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
MScott
  • OWF Model: CL 4030
« Reply #14 on: February 25, 2016, 03:43:58 PM »
The beauty of being off grid. My Daughter and SIL have been out of power most of the day, but my batteries are fully charged and the power is unaffected by the storm. :)
Eastern Ontario
Sthil MS 290
Sthil MS 180 C
Polaris ATV
Bush Buddy trailer
Wallenstein wood splitter
