Author Topic: De-scaling a boiler and piping?  (Read 5306 times)
ronh
« on: February 08, 2011, 09:27:43 AM »
Hello
Have a Central Boiler thats been running for 2 years with high alkaline (>9ph) water. Recently drained and re-filled with water from the conditioner (6.5ph). After 2 days the PH was back up to 9ph. I suspect there's lime and calcium still in the pipes, etc.
Anybody know of any solution you can put in the boiler to de-scale the thing before I drain and refill again. Its a 450 gallon system.
Thanks
Ron
tulenutn2o
  • OWF Brand: HeatSource1
  • OWF Model: Earth Energy 190
Re: De-scaling a boiler and piping?
« Reply #1 on: February 08, 2011, 10:36:36 AM »
I am a little confused. Our water hear is normally at 7ph out of tap boiler manufacturer recomends 7-10. I sent test in and tested 9.5 and they said GREAT! Boiler treatment raised it to that point. I had filled mine with softened water probably 290 gal + 30 or so tap as recomended by manufacturer.Mineral levels and such were great also. My understanding is that steel will not rust with high PH. Wood boiler solutions, I believe has a descaler. Scaling, though, I believe is more of a hard water concern. (water with high mineral content, etc.)
« Last Edit: February 08, 2011, 10:49:25 AM by tulenutn2o »
