Author Topic: Domestic hot water  (Read 19916 times)
trz
Domestic hot water
« on: March 18, 2016, 03:13:40 PM »
Having an issue with hot water. It seems it's never real hot but it is hotter sometimes more than other times. I think when we don't use it real often then when we do use it it is not very hot. Wondering if it would be losing heat sitting in the water heater. Anyone have that happen?
    I have a Hawkin Energy 1100
Domestic cold water comes in, enters top side of 30 plate w-w heat exchanger exits bottom from there it enters cold side of water heater exits hot side then into mixer valve and on through the house.   Mixer is set at hottest setting.
Any thoughts?
Re: Domestic hot water
« Reply #1 on: March 18, 2016, 03:50:33 PM »
in my opinion, you might as well leave power on to the hot water tank, it does not take much power to keep your water hot once there, the high cost of energy is to heat it from 50 degrees to your desired tempature there are other options but this is the easiest in my opinion as you are already plumbed up and running.
if you use very little hot water you could just bypass the hot water tank and use the plate exchanger to deliver "on demand"
add a small pump and circulate
add a thermo-syohon
dukethebeagle
  • OWF Model: 0001 hot tamali
« Reply #2 on: March 18, 2016, 03:57:02 PM »
get a sidearm
austin qc
bluegrass rules
proud appalachian
« Reply #3 on: March 18, 2016, 03:57:58 PM »
When was the last time you cleaned the flat plate?
« Reply #4 on: March 18, 2016, 05:00:49 PM »
While the OWB is up to temp, turn on a hot water faucet and then feel how hot the pipe is going into the tank and also out of the tank into the mixing valve. If it is real hot going into the mix valve, that may be the problem.
If you have a gas water heater and it sits a lot between usage then it can cool down a lot. Natural vent water heaters are the worst.
Like mentioned above, you can add a recirc pump or sidearm.
Or if you have a humidifier, hook it up to hot water and it will keep the water heater hot.
trz
« Reply #5 on: March 18, 2016, 05:29:57 PM »
It's an electric water heater if that makes any difference.
     I'm not familiat with what a sidearm is i'll have to do some research.
    Actually i do use a fair amount of hot water but, it sits all night and in the morn its not very hot.
« Reply #6 on: March 18, 2016, 05:40:23 PM »
Electric don't lose much heat because they don't have a vent up the center.
You shouldn't need a sidearm though. Your setup should work fine.
If your 30 plate around 5x12 inches? Also if you do the test running hot water, also check the boiler pipe after the plate. If your pump is too small or the plate is getting plugged it will probably be fairly cold.
braveblaster
  • OWF Brand: Ridgewood
  • OWF Model: 7500
« Reply #7 on: March 18, 2016, 07:22:53 PM »
How is OWB plumbing (hot water) set up to get to the exchanger and DWH, and how is it plumbed from there?
agriffinjd
  • OWF Model: BL 3444
« Reply #8 on: March 19, 2016, 08:23:14 AM »
I have a 20 plate running into the top of the electric water heater and it works great.  I have my boiler set point at 190 degrees.  What's your at?  If it's too low that may explain it.
U.P. of Michigan
Singlemalt
  • OWF Model: BL 2840
« Reply #9 on: March 19, 2016, 02:24:11 PM »
I had a check valve in the top of my electric hot water tank that caused my hot water to be very hot, cold and or tepid.
Removed the check valve and no issues since.
Kioti DS 4110 HS, Metavic 1150 log loader
Wallenstein FX 90 winch
Husky 257, 359, 346XP chainsaws
Ontario, Canada
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
« Reply #10 on: March 21, 2016, 04:09:08 AM »
get a sidearm
Ditto,,,, I had no luck with the plate.
Or use them in tandem
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
trz
« Reply #11 on: March 25, 2016, 10:04:11 AM »
So, how do you clean a plates?
   Did the check with hot water running, pipes are not a whole lot of difference going into the tank, coming out of the tank or after the mixing valve. At least not what i can feel by hand!
    Checked the water in my tank with candy thermometer it read about 120. Checked the water from the boiler as soon as it enters the house it was about 142.
     Went out to the boiler and water temp gauge read about 170( cant't believe i'm losing 30 between boiler and house)!
   Looked at humidistat and through the little window set on 160, but i don't know what the differential is. How do i tell?
trz
« Reply #12 on: March 25, 2016, 10:07:48 AM »
Not humidistat, meant aquastat!
« Reply #13 on: March 25, 2016, 10:21:44 AM »
Check the temperature of the boiler pipe before and after the plate while running hot water. If the boiler water coming out of the plate is fairly low then you probably need a larger pump or remove some restrictions.
How did you check the boiler water temp in the house? If through the pipe, you should do the same at the OWB end.
What brand is your OWB?
« Reply #14 on: March 25, 2016, 11:03:18 AM »
I use a short piece of garden hose wit two female ends, a five gallon bucket and a puddle pump with the garden hose adapter on it. Hook your garden hose to the flushing valves, the other end to the pump, place the pump in the bucket, add your cleaning solution ( i use white vinegar) then place another short hose from the other cleaning t into the bucket, then plug in the pump and let run.
Heres a picture from my setup.
