Author Topic: Electricity  (Read 12398 times)
Jared43758
  • OWF Model: C250
Electricity
« on: May 15, 2016, 06:33:48 AM »
Has anyone ever come up with a idea to use your owb to produce electricity. Even if it was only enuff to power its self, blower, pump.
Stihl MS290
Stihl MS660 Magnum
Husky 21 ton splitter
Southeast Ohio
Re: Electricity
« Reply #1 on: May 15, 2016, 06:53:01 AM »
I ran last years show G 200  with my 3500 watt Brigs on the gasses for a very brief time but the timing needed to be adjusted and wasn't, the result was a broken crankshaft!
Jared43758
  • OWF Model: C250
Re: Electricity
« Reply #2 on: May 15, 2016, 09:04:46 AM »
I wasn't really thinking something that used a engine because of the low life high maintence.  I was thinking of something that used the heat to create electricity, like how solar makes electricity or wind turbines do.  Not sure if something exsisted. If it doesn't it should
Stihl MS290
Stihl MS660 Magnum
Southeast Ohio
Re: Electricity
« Reply #3 on: May 15, 2016, 09:21:52 AM »
There are units out there that use heat for electricity but they are very expensive with a never ending payback and low output.
Re: Electricity
« Reply #4 on: May 15, 2016, 09:47:50 AM »
I can’t find it know, but a european company makes a unit that fits in the exhaust stack, works as the same principle as a stirling engine except uses helium if I remember correctly, very expensive and only produced at most 1kw.
ben
Re: Electricity
« Reply #5 on: May 16, 2016, 09:56:08 AM »
You could use peltier junctions. Especially if you used it in the winter, because they work best with a large temperature differential. That's what's in those little stove top fans that run off the heat of the stove. Hardly make any power though.
Ben
