Author Topic: Garage door  (Read 4791 times)
Roger2561
Garage door
« on: July 11, 2016, 07:19:57 AM »
Hi all - I have a garage door opening of 8ft tall.  I want to put in an overhead garage door but all I have for clearance is about 5 inches.  How does one go about installing a garage door with so little headroom space in which to work?  Thanks for the help.  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
2012 Honda Goldwing GL1800
New Hampshire
Re: Garage door
« Reply #1 on: July 11, 2016, 01:46:51 PM »
They make low clearance door tracks. I am not sure how low they can go but they should have it in the specs for them.
Roger2561
Re: Garage door
« Reply #2 on: July 11, 2016, 01:53:51 PM »
RSI - Thanks.  I'll look them up to see if they'll work for us.  Roger
JD LX277AWS
Stihl 021
Stihl MS 311
New Hampshire
Re: Garage door
« Reply #3 on: July 11, 2016, 03:58:09 PM »
Adding a garage door opener will be the tough part I imagine, maybe they have those in low clearance as well?
Cabo
  • OWF Brand: P & M
  • OWF Model: Optimizer 250
Re: Garage door
« Reply #4 on: July 11, 2016, 06:43:37 PM »
5" of clearance will be tough.  I think we have done them before with 8".  You should be able to order a door 7'9" if that will give you enough room.  Give Overhead Door a call or check at LaValleys.  Both are very knowledgable.
Re: Garage door
« Reply #5 on: July 11, 2016, 09:44:28 PM »
It looks like it can be done but not with torsion springs. The kits I saw said 9-1/2" for torsion or 4-1/2" for extension springs.
I would think a side mount opener would work.
