Author Topic: Winter Project  (Read 19756 times)
zimmie
Winter Project
« on: February 19, 2011, 03:18:32 PM »
This is a boiler that I am currently working on.  It is a bit more complicated than maybe I should have made it but it is a fun project.  I have learned alot during the last month of design and build.  Will post more pics.
zimmie
Re: Winter Project
« Reply #1 on: February 19, 2011, 03:19:59 PM »
more pics
zimmie
Re: Winter Project
« Reply #2 on: February 19, 2011, 03:21:59 PM »
30"x32"x42" Fire box
all 1/4" plate - top is 5/16"
zimmie
Re: Winter Project
« Reply #3 on: February 19, 2011, 03:32:12 PM »
water filled door almost done
jackel440
Re: Winter Project
« Reply #4 on: February 19, 2011, 07:03:36 PM »
Looking good! :thumbup:
I see you went with the waffle top on your fire box.What kind of water capacity you planning on?Are MIG or SMAW the chamber together?I would advise to make double passes.
Look forward to more pics
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
zimmie
Re: Winter Project
« Reply #5 on: February 20, 2011, 02:28:24 PM »
I did mostly MIG weld.  Some stick on the door.  Water capacity will be around 200 gallons.  I should have did double pass welding on the whole thing.  I will be going back over everything this week.  I had a hard time with getting the water chamber on the door sealed.  Planning to heat 1600sqft. Home and 1000sqft garage.   Hope it will do it.  I am up for any suggestions.
tulenutn2o
  • OWF Brand: HeatSource1
  • OWF Model: Earth Energy 190
Re: Winter Project
« Reply #6 on: February 21, 2011, 06:23:00 AM »
It will do the job. I'm with jackel, definately double pass on the welds. Keep us informed.
jackel440
Re: Winter Project
« Reply #7 on: February 21, 2011, 07:25:06 PM »
Make sure if you are MIG it I hope you have a bigger machine so you can burn in your root pass and get good penetration.I ended up with a few cold welds which I thought were fine.Building a tank to hold water and not leak ended up being a little more tricky than I expected.I was a little cocky thinking it would be no problem.LOL
Oh well live and learn ;)
New Holland LS170
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
zimmie
Re: Winter Project
« Reply #8 on: February 22, 2011, 05:44:21 PM »
Well I did weld both sides of everything.  I used .035 wire at about 25volts and 320wire speed.  But I think I will weld over everything agian just to be safe.  Thanks for the thoughts.  What do you suggest on the door seal?  Should I put silicone in the grove, lay the rope in and then silicone over the rope?
tulenutn2o
Re: Winter Project
« Reply #9 on: February 22, 2011, 05:52:44 PM »
Both will work. Kinda up to you. Heatsource1 uses silicone, lots of other units use rope. Jackel, what do ya think?
lawrencep
Re: Winter Project
« Reply #10 on: February 22, 2011, 06:06:41 PM »
i did what you said i put silicone down rope and went over it with silicone
zimmie
Re: Winter Project
« Reply #11 on: February 23, 2011, 05:06:00 AM »
I have heard someone one make mention to using wax paper between the outer silicone and  the door opening frame to create the indentation in the silicone.  The wax paper appearently will not allow the silicone to stick.
tulenutn2o
Re: Winter Project
« Reply #12 on: February 23, 2011, 11:33:57 AM »
That should work.
jackel440
Re: Winter Project
« Reply #13 on: February 23, 2011, 02:22:44 PM »
I just placed a bead of High temp silicone in the groove for my door ,and then placed the rope seal in the groove.This was to help hold the rope in the channel.I actually didn't even need it in there.
We install rope seal like this in our heatreating furnaces at work ,and they cycle 48x per 8 hour shift 7 days a week.(without the rtv in the door)That has worked on those big Carborizers for 50 yrs so why not stick to what works?We only change the rope seal if we start to get a slight leak.They are pressurised atmosphere so if they start to leak you will get some flame starting to lick out the door gasket.
I have no experiance using the rtv to make the seal on the door frame.I have read where a few guys have a had to dig thiers out and redo it.I don't see what is the benefit of it.I know it would be a heck of alot easier to pull a rope out and put in  a new one in about 5 minutes,Than scraping rtv out of a channel and then having to pump the channel full.Then trying to keep it flat as it sets up to make a good seal.I know it has been said to use wax paper and just lightly shut it.I see that as lost time and more hassle.Plus if its cold out and you need the OWB running your hosed. :bash:
I say rope seal,Adjust the door as the rope sets overtime.Then if it fails rip it out, put in new,throw another log on the fire and go back in the house >:D
« Last Edit: February 23, 2011, 02:24:22 PM by jackel440 »
New Holland LS170
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
zimmie
Re: Winter Project
« Reply #14 on: February 23, 2011, 06:16:03 PM »
Any thoughts on pressure testing the firebox for leaks?  I intend on applying compressed air to the firebox and spraying welds with soapy solution.  Will the door gasket seal enough to allow me to put pressure into the firebox?
