Author Topic: Kubota B7200 4x4 diesel tractor with attachments reduced  (Read 6279 times)
treeeman00
  • OWF Model: MF5000E
« on: October 12, 2016, 03:43:21 PM »
A am selling my kubota b7200 4x4 diesel tractor. Tractor runs and operates good. Has less than 1 hour on a brand new clutch and pressure plate and resurfaced flywheel. Has a new lift pump, New bearing in the steering box, New seals in the front right hub. Comes with a like new rear blade and boom pole. 3 pt hitch with 2 speed rear pto. It has a 60 inch cut belly mower that I can include but the deck needs work and the tractor does not have a front pto to run the mower. Hour meter shows 629 hours. Not sure if that's accurate. Valve cover has an oil leak, not bad. The 3 pt hitch works fine but the handle wants to float down on its own. As I said tho the 3pt hitch works fine and doesn't drift down unless the handle floats down. Tractor paint isn't the greatest and has dents and dings but the tractor operates good and the 4x4 works good. Asking 3200 obo. No trades don't ask. Call or txt 419 651 4250
« Last Edit: October 16, 2016, 11:40:07 AM by treeeman00 »
treeeman00
Re: Kubota B7200 4x4 diesel tractor with attachments reduced
« Reply #1 on: October 30, 2016, 06:54:36 PM »
Still have
