Author Topic: 3 amp fuse blowing on heat pump  (Read 5494 times)
JO42281
  • OWF Model: H5
« on: October 21, 2016, 10:01:27 PM »
So I tested my log burner to night and discovered that when I try to use my log burner t stat I blow the three amp fuse coming from my 24 vac xfm in my heat pump. If I run the heat pump t stat only which is isolated with a second 24vac relay everything runs fine. Anyone ever had this to happen? I know I have a short somewhere but I'm scratching my head right now. :bash:
Kubota 9000
Kubota 6800
Case 850
Silverado 2500
Silverado 1500
Ford F-250
Stihl ms290
Stihl ms362
Piedmont SC
Re: 3 amp fuse blowing on heat pump
« Reply #1 on: October 21, 2016, 11:32:30 PM »
Did you check all the wiring connections?
